Page 5 of 5 FirstFirst 12345
Results 61 to 71 of 71
Thread: sss progman
  1. #61
    Hungary
    When you update your progman also works well with isis files? I ediabas ini. configuration are suspected or changes iso Options
  2. #62
    I had that solved, it's about the Changes.iso that you applied, for the newer cars you must use a different Changes.iso
    best regards!
    Quote Originally Posted by imici85 View Post
    Hello
    There is an inpa K- CAN interface and working properly but Progman v32.E46 E91 ( 2006 / 3 ) this error write off
    I understand that only 2007 / 3 to d -can interface.
    Does anyone know what could be the problem?
  3. #63
    Quote Originally Posted by zsolty_szasz View Post
    yes, because in youre car is newer software then in SSS. Youre SSS is outdated. For this the only choise is to use ISIS
    you're wrong, I like to see well and precise answers not assumptions. SSS v32 was used until 2008 and that error has nothing to do with being oldm if the car had an update with ISIS it would of said outdated after the messuring plan.
    best regards!
  4. #64
    Hungary
    Quote Originally Posted by egyclick View Post
    best regards!
    I also have several changes iso, but I do not know what is good for me e91.Az iso changes, the problem is that the voltage falls off Progman 12v 40A charger and I use it. Where can I find a good iso changes?
  5. #65
    Hungary
    Again poorly written. E46 works well with it. E91 is only a problem with it. Other cars I could not try it out.
  6. #66
    I'm at work right now and don't have the file on my pc, I remember that I modified changes by xdrive.iso to show above 14V, your interface is not an intelligent tool like OPS/OPPS that can messure voltage that's why the voltage is coded in changes.iso to show exactly what it needs to work.
  7. #67
    Jul 2011
    Mine did the same,just had to start again,and it worked.
    Quote Originally Posted by cammy25 View Post
    *Did you change HWver after installing Base XP3.1?
    in windows\system32
    *Are you sure HDD is 80GB or bigger?
    *Are all drivers for hardware installed and recognised?
  8. #68
    Hungary
    Quote Originally Posted by paulb34 View Post
    The dll. files have been replaced. 80GB HDD.The driver of a multimedia video and processor driver did not install wm software tools. Win 7 on my computer ( HP Pavilion dv7 1166eg ) and HP has not issued an XP driver for it. Could this be the problem?
  9. #69
    Aug 2011
    hey guys, I have progman running on VM V.31. How can I upgrade??
  10. #70
    DK Veteran foxdata's Avatar
    IRAQ
    hi mate
    how can i set the ip address when i use ops with win xp and vmware using network rg45 cable
  11. #71
    The PC must have the IP address like: 192.168.0.50/255.255.255.0
    Must work.
