Results 1 to 11 of 11
    Default how do i burn a .iso without a .dvd file???
    how do i get a .dvd file from a .iso file?? and do i burn the .iso file ziped or unziped??
    cheers azza
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    You can use imgburn to create one or use notepad. In notepad
    gamename.iso
    Layerbreak= 1913760
    Thats assuming the layerbreak is the same on the new wave3 games, someone will tell you if its not
    EDIT: just re read your post. If you use winrar it will join all the files together and give you an iso there will probably be a .dvd file inside. If not see above
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by azzadinga View Post
    cheers azza
    Run the iso thro ABGX, it will create 1 for you
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Or Cunny will give you an easier answer
    thanks cunny relised that about 5 min after the post.. thanks guys for the quick replies.
    cheer azza
    DK Veteran djjwdubz's Avatar
    dudley west midz
    use Xbox Backup Creator its free to download and it does it for you
    ev ery game i download i put thru abg it sorts it out if there is any probs
    V.I.P. Member alunfennell's Avatar
    Oct 2008
    Either use abgx360 to create a file .dvd file for you or create you own.
    1. Open Notepad
    2. Copy and paste what i write below
    LayerBreak=1913760
    XXXXXXXXX.iso
    3. Where i have put XXXXXXX's remove these and write in the name of the .iso
    Example :
    LayerBreak=1913760
    SHIFT.iso [that bold part is the title of the game .iso you downloaded]
    4. Save the file as the title of the game [xbox360iso.dvd]
    5. Use the .dvd file you just created to open up image burn
    Regards:
    Alun
    dudley west midz
    sorry off topic. i have used a dvd dl dvd to burn season 1 and 2 of prison break but when i put them in my xbox only some work so do i have to do the same as the xbox games and make a .dvd file thanks 4 any help
    Quote Originally Posted by alunfennell View Post
    1. Open Notepad
    LayerBreak=1913760
    XXXXXXXXX.iso
    Example :
    LayerBreak=1913760
    Regards:
    Alun
    The easy, fast and reliable way...
    Quote Originally Posted by djjwdubz View Post
    No, you don't need to.
    Have you tested this DVDs that you have burn in another DVD Player ?? Maybe it is corrupted.
