    amrif's Avatar
    EU
    Default 307 1.6hdi EGR disconnect the plug solution
    hello, EGR Actuator plug have be disconnected. Can someone help me? When I disable P04xx I have esp mill light and dtc:U1208 :/
    THX
    If I helped you please remember to give thanks and rep. A little thanks goes a long way
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    You know that is no problem just disabled dtc
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
    Act Tuning's Avatar
    Sep 2016
    Around
    Quote Originally Posted by boomeer View Post
    good joke, so if you delete dtc only esp light go off you think ?!!
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    l remember reading about these over the years on these its a common fault even comm 2000 , might be nothing to do with what your doing unless ori files turns it off that is
    cant think why egr would do that ,,
    l would try another file
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    I don't think like you I have good results in practice. ... for act tuning
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Try this file
  7. The Following 3 Users Say Thank You to konq100 For This Useful Post:
    amrif (2nd January, 2017), bobolin4o (3rd January, 2017), stanislav georgiev (3rd January, 2017)
