Results 1 to 12 of 12
    DK Veteran dollarbill's Avatar
    france,paris
    Default q7 2012 all key lost
    hi for all
    i have a q7 2012 all key lost i try with avdi original for extract pin in the ecu ecu is edc17cp44 but don't work i put ecu on bench for a try with option direct pin is the same can't extract the pin i wouldn't open the ecu . i remove ezs i open it but inside is nec chip my question is i can read this nec chip or is the same of ezs mercedes with nec i can't read ? thanks for answer
    cordially
    if i help don't forget a thanks
    Jan 2016
    Maartinj's Avatar
    Nov 2010
    immo 5th .... BCM2
  4. The Following User Says Thank You to Maartinj For This Useful Post:
    dollarbill (4th January, 2017)
    france,paris
    You sure ?
    Jan 2016
    I've posted the same as Maartinj I wasn't sure and earase my post
    Car has key like A6 4F or is it smart key ??
  7. The Following User Says Thank You to amigokola For This Useful Post:
  8. #6
    france,paris
    The car have key a6 4f
  9. #7
    Usa
    cod for ELV?
  10. #8
    rob h's Avatar
    May 2011
    Immo is not in ezs.
    Check the elv.
    J519 module, with 0L01Y motorola.
    Download vvdiprog software, and run it without hardware.
  11. The Following User Says Thank You to rob h For This Useful Post:
    dollarbill (5th January, 2017)
  12. #9
    Fallen's Avatar
    2011+ with all keys lost cant be done at the moment.
    I was able to extract CS and login from the same ECU on the bench but AVDI could not program the keys, even with this information.
    AVDI tech support wasted 2 days of my time on this car.
  13. The Following 2 Users Say Thank You to Fallen For This Useful Post:
    dollarbill (5th January, 2017), yugo45 (5th January, 2017)
  14. #10
    Jan 2016
    Rob J-519 is onbord supply control unit (central electric module)
    J-518 is entry and start authorisation module (ELV) where immo info is stored in.
    I think dollarbill read wrong module. In ELV always is Motorola in this case should be:
    Quote Originally Posted by rob h View Post
    Immo is not in ezs.
    Check the elv.
  15. #11
    france,paris
    Ok thanks for help at all i say customer is not possible for me
  16. #12
    france,paris
    Quote Originally Posted by Fallen View Post
    it's the support of avdi !!! Me I do not ask to support i never have a response or never good solution if i have problem ....
