Yes, it is after 2004 model. But immo off solution work only one main relay switch. I will try immo off afain and ori, will see.
Ok, problem solved. The reason of no MIL lighting was coused by second hand alarm wiring! When I put orginal dump and cut alarm instalation engine run and starts again... But immo off solution for IAW 4AF.SM not set becouse don't know which ECU line should be cutted... Thanks to all active members. Regards.
yes somethink else bad i think some of power to ecu, if mil no light
Plug N Play
To anyone who need it
Press Reputation +1 = Password in PM
regards
88diablo (14th October, 2019), janodrgon (18th June, 2018), SGSERVICE (2nd June, 2023), vucinabih42 (28th December, 2021), Zwyczajny (21st December, 2022)
Could I get the password please.
Or could someone make my dump immo off please.
Hi, I know its old but It was the file from gkogkolos a couple of posts up that I was after the password for to see if it worked as a generic free run file or I attached my own file if someone could immo off fro me.
https://www.digital-kaos.co.uk/forum...HW407-immo-off
https://www.digital-kaos.co.uk/forum...AF-SS-IMMO-OFF
read secobd thread tells you whatvto write
88diablo (15th October, 2019)
