Results 1 to 13 of 13
    Jul 2016
    Default How to repair the BMW electronic handbrake parking EMF control unit?
    Hello everyone
    BMW X5 X6 E70 E71 electronic hand brake EMF control unit module
    We often encounter, EMF control unit, internal failure
    This failure, we can successfully repair
    First, let's look at the location and appearance of the EMF, as follows:
    Shell number is this, as follows:
    Open EMF is the case, as follows:
    Open the PCB of the control unit as follows:
    We need to do is:
    1: Replace the motor
    2: Check the motor behind the two wiring, to ensure good
    3: Replace the blue relay
    4:Check the other side of the motor gear (not the motor's own gear, please note), because it is colloid, long working wear, deformation, if the deformation is serious, need to replace the processing
    Because my English is not good, there are many details can not be more clearly expressed, please understand that if you have a better maintenance methods, you can reply to this post below the discussion.
    bearheroes's Avatar
    Dec 2011
    Thank you very much for your advertisement!
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
    Member Nicolos's Avatar
    Aug 2018
    Belgium
    What is the fault code from diagnostic?
    i have 2 EMF modules with internal error. I check motor and it seem to be OK. On test current is 2A.
    relay is OK on test.
    Any info about repairing internal error?
    BR
    rubin_miki's Avatar
    Nov 2008
    MAKEDONIJA PRILEP
    What memory is inside?25080?
    Quote Originally Posted by rubin_miki View Post
    yes - 25080 inside
    rubin_miki's Avatar
    Nov 2008
    MAKEDONIJA PRILEP
    Default emf
    here is eep,its from e70.but you need to do test ride with diagnostic tool (we do it with kts)
  8. The Following 18 Users Say Thank You to rubin_miki For This Useful Post:
    ASCM (19th March, 2021), beongo (3rd March, 2020), chiorbeq (29th January, 2021), delio78 (3rd July, 2019), Donabe (28th March, 2022), leandroks (28th July, 2020), Molixcr (10th June, 2023), Nevidimia (31st October, 2023), padman (15th October, 2022), pekelan (2nd February, 2020), plamen 63 (10th January, 2022), raskolnikov1975 (1st July, 2020), Rider667 (27th May, 2024), saidiag (3rd July, 2019), scoot (22nd January, 2019), smailuk (26th October, 2023), valdi1410 (31st March, 2021), zoranmadzar (11th May, 2019)
    Thanks for dump.
    I will try next days
    BR
  10. #9
    Sep 2014
    Did the eeprom clear your error ? I have E70 now with fault code 600D - control unit internal fault.
    Thanks.
    Br,
  11. #10
    Nov 2010
    This file is working correctly, the error code 600D has been deleted and EMF works again
    Thank you.
    Best regards.
  12. #11
    McDowell's Avatar
    Feb 2019
    Zamunda
    Hello mates,
    I am having 600E and 6011 fauls internal fault- on the following X5 BMW Parking brake, I saw that relay was faulty but stil faulty, I thought on EE faulty but checking I have seen also a burnt fuse. I have repaired it but not sure if 95080 is also faulty. Could you check or give us good one?
    I am attaching 95080 EE
    Thank you very much in advance
  13. #12
    karmoranas's Avatar
    Jan 2013
    Lithuania
    hello friends, have problem with bmw e70 EMF , o open emf module and find blow fuse, and bad relay blue . i changed it , check motor . but get fault 6011 EMF Control unit, : internal faul Engine circut , any solution to remove this fault from dump ? i just want to get no fault on dash...
    If i Help , please push Thanks
  14. #13
    Mar 2024
    Hello need a emf dump for a e70
