Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    soxten's Avatar
    Mar 2013
    Default How to clone Bmw FEM modul?
    I have a Bmw 3 F30 2013 FEM-module here.
    Is it possible to clone this unit?
    Mcu is 2 and SPC5668EVMG (0N61C)
    Eeprom is 95128 and 95256
    Top Poster Tbolbi's Avatar
    Sep 2010
    TuNiSiA
    hello
    as i know is not possible to clone or make keys for a BMW with FEM-module.
    PAIN is Not Our Enemy.. It is a Call To GREATNESS!!
    soxten's Avatar
    Mar 2013
    Is mcu handling keys to decrypt Eeprom or?
    what tool can read SPC5668 mcu?
    This tool I think can read SPC5668
    http://www.nxp.com/products/software...W_TAP#overview
    Here is info about mcu.
    http://www.nxp.com/products/automoti...68G?lang_cd=en
  4. The Following User Says Thank You to soxten For This Useful Post:
    kyawkyaw (10th February, 2018)
    bearheroes's Avatar
    Dec 2011
    Only way until now is transfer bga chips and eeproms...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  6. The Following 6 Users Say Thank You to bearheroes For This Useful Post:
    caliskan71 (11th January, 2017), gokhanusta (11th January, 2017), kamilmaly (3rd July, 2021), soxten (11th January, 2017), thug252 (9th February, 2018), ucokseparoh (30th July, 2017)
    Hello Sox, Transfer BGA and EEPROMS and will work. But be carefull how you unsoldier bga's ... they have glue under it ... after u succesfuly remove bgas from both plates .... donor and original you have to carefully clean glue from donor pcb. Watch for pins ... i usualy clean with not to hoot round soldier tip but ... be very careful mate those pins on pcb like to fall off ...
    I wish you good luck
    Regards friend!
  8. The Following User Says Thank You to fruti For This Useful Post:
  9. #6
    May 2016
    I'm repairing flooded F30, I was in luck, original FEM was just enough alive. Kombi is non-responsive.
    I just want to confirm, Transfer BGAs and EEPROMs works!
    After transfer, there is just one problem, milage is 0. Obvious its stored somewhere else.
  10. The Following 6 Users Say Thank You to t22 For This Useful Post:
    duplikeytor (22nd March, 2017), nenadgorgi (22nd March, 2017), salkapone (22nd April, 2019), shpuncik (24th May, 2019), sniegavirs (8th February, 2018), soxten (21st March, 2017)
  11. #7
    May 2016
    Hi all,
    I got used identical kombi (donor), I have red dot and ISTA says vehicle ID mismatch (or something). Now I have two options:
    1. Write VIN in donor eeprom (160D0WT)
    2. Transfer eeprom (actual there is one more nearby 95080WT)
    What option do you recommend?
  12. #8
    Apr 2016
    Hi t22,
    I suggest to desolder eep 160D0WT from your non responsive original cluster and put it
    into your replacement cluster and check what happens. You should get your original mileage then.
    Good luck
  13. The Following User Says Thank You to tigex For This Useful Post:
    t22 (21st July, 2017)
  14. #9
    immokill's Avatar
    Jun 2009
    UNIVERSE
    write vin and all ok . if you just replace eep first do backup of it .
    Here to HELP!
  15. #10
    soxten's Avatar
    Mar 2013
    Quote Originally Posted by immokill View Post
    Is VIN like immo code?
    To clone this typ, only clone Eeprom?
    Skickat fr?n min iPhone med Tapatalk
  16. #11
    May 2016
    Thanks tigex,
    I desoldered and transfered 160D0WT from original damaged cluster to donor. Red dot remained, but Istad came with new fault, "unknown eeprom version". So the eeprom have some chip ID or serial nr. and CPU checks this.
    I end up with buying smok. I cleared VIN and incremental area in donor eeprom. I put it in the car. Red dot gone, odometer correct. All good and working. I don't know why, but I got +3km in odometer.
    My next project is to change head unit Magneti Mareli (HU_ENTRYNRAV) with used one. I can't get navigation to work on donor even with can filter. Navigation in menu is greyed out. AppNr. is DF. FSC codes are missing, because donor car did not had navigation option, but GPS hardware is present. If someone knows the way besides buying new unit...maybe chip transfer again?
    BMW wants to sell new items, but that all of them wants.
    Now I have smok for sale
  17. The Following User Says Thank You to t22 For This Useful Post:
    immokill (21st July, 2017)
  18. #12
    immokill's Avatar
    Jun 2009
    UNIVERSE
    you put all ff in vin ?
    Here to HELP!
  19. #13
    May 2016
    Yes. And zeroes for incremental/odometer.
  20. The Following User Says Thank You to t22 For This Useful Post:
    duplikeytor (12th February, 2018)
  21. #14
    May 2016
    Quote Originally Posted by t22 View Post
    I know that this has nothing in common with cloning FEM but I will write anyway may somebody have the same problem. All right, that was easy, as I look back. FSC (certificates) should be with status "Accepted" and issued with same VIN as HU (headunit). HU VIN in my case was different. So I changed HU VIN to VIN written in FSC. Then I "Update" FSC and with this status changed from "Rejected" to "Accepted". After resetting HU Navigation works.
  22. #15
    Feb 2018
    Hi, sorry for bring this post up, but I'm now trying to repair a flood F30 as well, are the two big chips called BGA and the two small ones EEPROM? In order to make a used FEM work, I have to transfer all four of them correct?
