Results 1 to 3 of 3
    Aug 2012
    Default Digiprog3 and Tachosoft
    Someone has a guidance for me how I use the software "Tachosoft"?
    And can I then enter the data from hand into the digiprog?
    Thanks in advance
    Sep 2015
    Hello my friend is very easy there is the tachosoft tells you
    Mar 2017
    There is not much to it. Open the soft, select the car, enter desired km in "odometer value" textfield, click calculate, use generated string to modify dump. Refer to the text displayed on the bottom part of the soft when you select the car to get some guidance on chip type, and locations you need to modify in dump. And yes you can enter the data manually on digiprog using the eeprom menu (you have to read the eeprom first).
  4. The Following 2 Users Say Thank You to wokcz For This Useful Post:
    julespatch (6th September, 2017), miguel007nz (29th July, 2017)
