Page 2 of 8 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 114
  1. #16
    Apr 2008
    the main issue you have here is that you have a none UK image on your box,
    Borrowed from Al cheers m8
    FTP into /var/tuxbox/conf and edit the settings I've marked in red to your known local settings in the scan.conf file...
    TP_fec=3
    TP_freq=643000
    TP_pol=0
    TP_rate=6887
    TP_satname=
    TP_scan=0
    bouquetMode=2
    delivery_system=0
    diseqcMode=0
    diseqcRepeat=0
    netid=00005
    satCount=0
    satNameNoDiseqc=Virg*n Media
    scanSectionsd=0
    scanType=0
    scan_mode=1
    Mimic all the other dark blue settings as above- and make sure the green item reads like mine. (replacing the * with i of course; this is board safety in action). This links into the cables.xml file and will enable you to toggle to another provider if you are NOT 6887 nor 6952 (VM)
    Then SAVE the file and Reboot your box (or the changes won't work!), Then try a Scan again.
    Last edited by Renwich; 26th July, 2008 at 09:20 PM. Reason: Automerged Doublepost
  2. #17
    DK Veteran cablefreejunkie's Avatar
    Jul 2008
    on a sheet of lino
    how do i ftp into ???
  3. #18
    plasterer's Avatar
    Jun 2008
    Mersyside
    Download an Ftp proggy
    And read the How to s in the Search
    Once you get the Hang of this
    Your D Box probs will be gone forever
    Its a must ....Paul
    PAUL
  4. #19
    Jun 2008
    Quote Originally Posted by cablefreejunkie View Post
    u need a ethernet (network or patch) cable to connect to box and then use an ftp app like flashfxp
    u use a normal cable if u connect through a router (hub)
    or a similar cable but a couple of the wires crossed known as a cross-over ethernet (network or patch) cable if direct to your pc
    or if u only got a normal cable u could use an adapter
    Maplin UTP Crossover Adaptor (Male - Female)
  5. #20
    Jul 2008
    on a sheet of lino
    total novice here,i know how to connect the box to my pc but the other actions i havent got a clue,,,,thanks for all the replys,,,,,i have got channels now but a lot of them im still getting the error channel not available on the screen,dont want to keep bugging users on how to do this and that
  6. #21
    plasterer's Avatar
    Jun 2008
    Mersyside
    Your gettin there mate
    Its a slow lerning curve
    But once yoiu get round the bend
    Its all Fun action .....Paul
    (Well done so far)
    PAUL
  7. #22
    Jul 2008
    on a sheet of lino
    i have looked in the download section but cant find anything that resembles ftp proggy,what exactly is this ? i can just about fire up my laptop alone,so an ftp proggy is way out of my league,but i am willing to learn about this box and get it sorted,could someone please point me to the correct file ?
  8. #23
    Jun 2008
    Digital Kaos - Downloads - FlashFxp
  9. #24
    Jul 2008
    Goto hallenberg.com and u can download these files here Hope this helps.
  10. #25
    Jul 2008
    on a sheet of lino
    looks like a site i might be interested in,trouble is i dont speak german,thanks anyway for the link info
    <--cablefreejunkie added 551 Minutes and 52 Seconds later...-->
    hello again.im about to ftp into my dbox and edit some settings,now i have a wireless router,so my question is this:what cable do i use ? ethernet crossover or straight through ethernet and where do i plug the cable into ? my dbox to router or dbox to pc ? i have been doing a lot of research but one thing i still cant get my head around is the image thingy,what is the image ? is this the main software on my dbox ? why are there so many different images ? whats the best one for me ? i just want all the channels to work without any hassle,i dont want much !!
    Last edited by cablefreejunkie; 28th July, 2008 at 06:54 AM. Reason: Automerged Doublepost
  11. #26
    Jun 2008
    i've always used a router and never had a prob connecting...use a straight ethernet cable...go into your dbox/settings/network....
    set ipaddress 1 number above your pc ip addy or in the range of ur router
    set default gateway to the ip address of ur router and
    set dns server to the address of ur pc
    eg
    IP Address 192.168.1.3 - dbox
    Default Gateway 192.168.1.1 - router
    DNS Server 192.168.1.2 - pc
    The img is all the software on ur box always 7.87 MB / 8,064 KB if ur img ain't this size don't flash it and it has to be the same as your box 1x or 2x chip.
    All boxes seem to be different it's a matter of 'sucking and see' which one best suits your box....i'm forever flashing new imgs just for the fun of it but once ur happy with an img then stick to it....but you'll never know if the latest one created is better....
    ps after any mod to ur image save it, save bouquets, service and ke*y files after any change...can't stress enough to save regularly, best bit of advice i was given when first starting out....
  12. #27
    Jul 2008
    on a sheet of lino
    ok,im now connected through the flashfxp to my dbox,previously i was told to go into scanconfig file and change some settings,how do i get into this file ? do i need to transfer it from the dbox to my pc first using the flashfxp ? im totally confused
    <--cablefreejunkie added 20 Minutes and 15 Seconds later...-->
    the problem i have is that most of the channels i get the error channel not available mesage on the screen,the only channels available are bb 123 it 1 and 4 and 5 nothing else is available,im being told to do all sorts of actions on here that i havent got a clue how to do,i was told to get the flashfxp which i have done and connect and go to var/tux/config and edit settings,i have got to this folder but the files i cannot open,do they need to be transfered to my pc first ? am i doing the right actions for the problem i have with my d-box ????
    Last edited by cablefreejunkie; 28th July, 2008 at 11:05 AM. Reason: Automerged Doublepost
  13. #28
    Jun 2008
    if u can see the files that's good....have a look in var/keys....do u have the new nagrarom7 file to transfer across? it may be worth saving ur img as it is first....go into press dbox/settings/service/backupimg or expert user...save img back up one partition.....then use flashfxp look in the tmp folder and u will see a file called mtd3 or 4 right click on this and transfer to pc...
    <--MetMan added 1 Minutes and 18 Seconds later...-->
    if u need the files pm me ur email addy and i'll send them to u
  14. #29
    Jul 2008
    on a sheet of lino
    i have the nagrarom file 7 but not the mtd 3 or 4 i have created a back up image but couldnt do it the way you said,i had to go into the sportster menu,anyway thats done now,what next ??
  15. #30
    Jun 2008
    transfer the nagrarom7 file into the keys folder var/keys probably i don't use sportster, overwrite the one thats there
