Someone help?
Someone help?
your file off mate, dont forget thanks
bodzio012 (13th January, 2017)
Big thanks Mate!
excuse errors
After DPD OFF I have fault DTC200262 read by clip and other scanner DTC2002, all reset after write DPF OFF
Ewentaully DTC 2002 OFF from org file???
Then I copy to DPF OFF file
try this solution
Thanks tricore but still the same fault DTC2002
sorry mate i dont have more solutions, i think taht you need to force a regeneration. i can't erase dtc, sorry
Ok. Thanks Mate.
I tried regeneration but stop after some minuts because fault DTC2002
Put adress 1be4a1 8 bit view to 0 and P2002 will gone.
bodzio012 (15th January, 2017), kinketotua (15th January, 2017), mecafrigo (15th January, 2017), stanislav georgiev (15th January, 2017), vlaki electric (28th January, 2017)
If not runs try these. you can unplug diferencial sensor pressure and temperature sensors
-> Attachment 421464
bodzio012 (15th January, 2017), carbon7319 (15th January, 2017), drewdom (15th January, 2017), mecafrigo (15th January, 2017), stanislav georgiev (15th January, 2017)
Thanks all. Carbon DTC OFF working, all ok. Thanks again
