Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 91
    Member akyboo's Avatar
    Jan 2009
    Cork, Ireland
    Default Wii Softmod for Dummies(without Zelda)Reupload
    this soft mod uses the bannerbomb crack read the pdf file and follow the instructions and all should be fine. I have not tested this on version 4 but feedback would be welcome. Print out the pdf. file before you do anything read it twice and follow the instructions precisely step by step.
    For those downloading the games use the Patcher to convert all the games burn at slow speed( i burn at 4x using nero) use verbatim - (not +)discs. This is for versions 3 wii's.Please do not use this thread for first post, the thread is to help those that need help and advice.
    New members please read here first akyboo Please Read Before Posting
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    thing is where is the pdf file ??? not in the zip
    Quote Originally Posted by akyboo View Post
    Hi, Any one tested it with Ver.4 yet?
    Does this work on all previous versions up to 4.x??Has anyone succeeded with this? Totally looking forward to trying this out!
    which version is this for?
    Have this been amended yet? What is the best version to use?
    Default Wii hack
    Thank dude i've been looking for a way to softmod my wii without LOZTW for a while now!!
    Im about to try this now, I must admit im completely lost after reading so many tuorials but this one seems to have good feedback. Just one question does it matter what type of SD card i use?
    Apr 2009
    downloaded and im going to try it at the weekend after a bit more reading,, thanks for the files mate
    Default Pleeeese Help.........?
    I finally got my tester game "Mad Tracks" to work this morning but it was gray so I just continued installing them stupid IOS's and now all the sudden every app I try goes black. My HBC works to. I had updated to 4.2 before I softmodded and everything started to work until now. Someone pleeeeeese help. Is there a way I can start at the beginning?
    so this Will Work on every version of Wii or are there some that aren't compatible?
    Do I need to download Zelda in order to play games from another region? I bought my Wii in the EU and then bought some games from the US, not really thinking that it would be a problem to make them work on the EU Wii but....
    Now I am a little confused; Can I use this tutorial to make the games work or do I also need to download Zelda?
  13. #13
    V.I.P. Member ck-ok's Avatar
    nottingham
    spideyalert this softmod was not for 4.2 thats why its all going wrong follow a guide for 4.2 should get you back on track
  14. #14
    i get error -2011 when i try to instal a wad
  15. #15
    so just to clarify, this will work on firmware 4.0E? and ill be able to run homebrew/backups?
    will i need to do any additional steps to use a usb drive?
