Results 1 to 2 of 2
    wiseman's Avatar
    Default BERLINGO EDC117C10_ DPF_EGR_ADDITIVE is it actually possible
    I have tried and tried to remove all and still have Engine triangle and display on dash engine fault. No fault codes
    1 fault in Addtive ECU EB0 Unknown
    Codded out in BSI also
    Orig file here
    berlingo_flash orig_edc17c10.rar
    mihaiservice's Avatar
    http://www.quick-tuning.com
    this one should be ok,you can disconnect all you need from dpf or additiv !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  3. The Following User Says Thank You to mihaiservice For This Useful Post:
    kinketotua (15th January, 2017)
