Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    soxten's Avatar
    Mar 2013
    Default Clone Ford Mustang 4.6L 2004 ECM need help
    Hi all
    I have a Ford Mustang 2004 with 4.6L
    Ecu/Ecm is "Ford" EEC-V
    Where is immo located?
    I have some type of Eeprom on right side of pcb, "032FB PEDH"
    And und bottom side i have some flash "N70005FWC002" "SL5TR"
    I have a same used ecm/ecu as I need to
    move immo to from broken.
    Ned help ehat chip this is and where immo is.
    Skickat fr?n min iPhone med Tapatalk
    Apr 2016
    Canis Majoris
    try guys at www.moates.net. (Support)
    They have great experience with these ecus.
    But i think immo will be in eprom 95040 (marked as ST77012 or ST77014). May will be on the lower side of the board.
    If i helped please push the magic buttons "thanks" and "reputation"
  3. The Following User Says Thank You to KCSS For This Useful Post:
    soxten (16th January, 2017)
    soxten's Avatar
    Mar 2013
    Dont need more tools, need to know where immo is for clone this ecu.
    I have tools for read Eeprom and flash.
    Hope someone can help me with info what part I need to clone to get my used ecu to work.
    I dont have car here so I need to fix all on bench
    Apr 2016
    search soic-8 IC marked as 77014NC = 95040
  6. #5
    Jan 2010
    DUPNICA BULGARIA
    Other side on PCB is located 77014
  7. #6
    soxten's Avatar
    Mar 2013
    Cant find?
  8. #7
    soxten's Avatar
    Mar 2013
    Any ide? Need help on this one
  9. #8
    vanos batam's Avatar
    Jul 2010
    Batam-Indonesia
    Try TMS...
  10. The Following User Says Thank You to vanos batam For This Useful Post:
    soxten (17th January, 2017)
  11. #9
    soxten's Avatar
    Mar 2013
    I have try to read this as 27C010 and 27C512 but no info in reading.
    Please need help
  12. #10
    soxten's Avatar
    Mar 2013
    I did change mcu and car starts!
  13. #11
    Apr 2017
    الخليج
    sorey i have same bropleam and i cant locate mcu yo can helep
    me
  14. #12
    Jan 2018
    ITS ON FLASH NOT EEPROM (N70005FWCHCA) ITS 28F010
  15. #13
    soxten's Avatar
    Mar 2013
    Change N7000... chip as under mcu and car starts!
    Skickat från min iPhone med Tapatalk
  16. #14
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by soxten View Post
    Bump into this thread...
    I´m trying to read a Ford ECU (kess identifies as a EEC-V ECU) to change the VIN (there was some issues with the Vin Block and someone tried to write VIN with HPTuners, now VIN is a "mess"...
    I was able to read this with Kess but now i cant write. Alrady tried in car and in bench and same result.
    Kess Error: "Change of Status Not Possible".
    Can you tell me if i can read flash using any programmer like TL866Pro?
    For what i see, it seems that flash is chip with ID: N70005FWC002 (seems to be same has yours).
    How can i read this if i remove from PCB?
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  17. #15
    Apr 2020
    KSA
    Hi Mate can you share how do you get to read this Flash N70005FWC002 if you have a pin out or data sheet, Cause I have also this type of flash in ford focus 2003 gas and I want read. I did not find the data sheet in the google. Please help
