Results 1 to 9 of 9
    Jan 2017
    Default ME 3.8.3 IMMO OFF Request
    Hello i read my eeprom from the ecu and i need immo off.
    My chip is 24C04
    ECU 06A 906 018 CG ME 3.8.3
    The file i read it seems empty the previous owner of the ecu go the tuner to turn it off.
    I think he just changed the chip to empty one and scam him.
    I uploaded e2p file and bin i don't know which one you need guys!Thanks!
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Both are bad.
    Scripts for Multi-PROG
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
    dragon100's Avatar
    Jan 2012
    Both are bad. Try this off.
    Best regards.
    Dragon
  4. The Following User Says Thank You to dragon100 For This Useful Post:
    mvalev (16th January, 2017)
    Jan 2017
    Thank you i will try the file can i flash this on 24C02?
  6. #5
    dragon100's Avatar
    Jan 2012
    Write only 24c02, no flash.
    Best regards.
    Dragon
  7. The Following User Says Thank You to dragon100 For This Useful Post:
    mvalev (19th January, 2017)
  8. #6
    Jan 2017
    Yeah by flash i mean program the chip.Do i need enable write protection?
  9. #7
    dragon100's Avatar
    Jan 2012
    no only write and if car have immobox, disconnect it.
    Best regards.
    Dragon
  10. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    Kayhan 17# (2nd February, 2020), mvalev (19th January, 2017)
  11. #8
    Jan 2017
    Ok,thank you!
  12. #9
    Jan 2017
    Everything works perfect.
  13. The Following User Says Thank You to mvalev For This Useful Post:
    dragon100 (19th January, 2017)
