Results 1 to 5 of 5
    Jan 2016
    Default Iveco Daily EDC17CP52 tachograph failture engine rpm limit
    Good day!
    If there's a kind person who will help to disable the engine rpm limit?
    Now, the speed is limited to 2500-3000 rpm and do not far faster 90km/h due to a broken tachograph.
    Iveco Daily 2012y.
    Bosh EDC17CP52 Tricor boot mode, readed with FGtech Galletto v 54
    flash.zip
    Dec 2015
    PL
  3. The Following 2 Users Say Thank You to mateusz1611 For This Useful Post:
    komiss (21st January, 2017), sonic 1989 (20th January, 2017)
    Jan 2016
    infortunateli, does not vork, stil limited...
    Jan 2016
    I have some news about tachograph remove problem.
    When tacho is disconnected, in the ECU writen DTc:
    С49B87(U049B) -can line, the TC01 message transmission delay
    C42287(U0422) - can line, data send delay
    72264 - speed sensor on shaft
    The usual solution of speed limit has no affect, because tachograph miss limit restricts the engine to 2500-3000 rpm.
    It possible to trace this DTC`s and disable tachograph verification function?
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Use iveco easy tool. and 5 min job .
    Here to HELP!
