Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Jan 2017
    colombia
    Default Radio code PANASONIC EPROM 24c25
    Hello colleagues could help me with the radio code PANASONIC with EPROM 24c25 send the file and serial number
    thank you very much
    IMG_20170119_093437.jpg.
    Jan 2010
    DUPNICA BULGARIA
    Try to read agin eeprom like 24C256
  3. The Following User Says Thank You to ilian_cho For This Useful Post:
    luis marin (27th January, 2017)
    Apr 2010
    Chrysler [RE6]
    S/N T M9 340 2 01013
    Code = 9086
  5. The Following 2 Users Say Thank You to Rdecode For This Useful Post:
    Car235 (21st January, 2017), luis marin (27th January, 2017)
  6. #4
    Jan 2017
    colombia
    Quote Originally Posted by Rdecode View Post
    Chrysler [RE6]
    Code = 9086
    Hello, my friend, the code is wrong please could you help me again
  7. #5
    Jan 2017
    colombia
    Hello eprom reading 24c256 code thanks
  8. #6
    Feb 2010
    WALES
    Quote Originally Posted by luis marin View Post
    Can you try 0451
    wbr
  9. The Following User Says Thank You to shooting For This Useful Post:
  10. #7
    Jan 2017
    colombia
    [Quote = disparos; 2939120] Se puede tratar 0451
    WBR [/ quote]
    Hello friend that code is incorrect you think you would have another option to solve it thanks
  11. #8
    Sep 2009
    1. try code 4263
    2. why written 2 different vin ?
  12. The Following 2 Users Say Thank You to nikz For This Useful Post:
    luis marin (27th January, 2017), shooting (24th January, 2017)
  13. #9
    Jan 2017
    colombia
    Quote Originally Posted by nikz View Post
    1. try code 4263
    The first reading of the vin was done 24c25 but then they told me to read 24c256 so two lectures were done
  14. #10
    Jan 2017
    colombia
    1. try code 4263
    Friend the code is not right look what appears to me
  15. #11
    Apr 2010
    The code is 100% correct for the radio label you have attached,
    Model: P05091464AF
    Code = 9086
    The problem is that dump attached is for different radio - P05091465AE
    https://www.carstereocode.com/unlock.php?id=4474
    So, code for which radio are you requesting?
    P05091464AF or P05091465AE ???
    Write original dump in P05091464AF with serial T M9 340 2 01013 and enter the code 9086
  16. The Following User Says Thank You to Rdecode For This Useful Post:
  17. #12
    Jan 2017
    colombia
    Model: P05091464AF
    Code = 9086
    http://www.radiocode.ivgsoft.com/radiocode.php?id=4474
    Thanks the code I need is for .P05091464AF
  18. #13
    Apr 2010
    You have code for P05091464AF already - 9086, but your dump is for P05091465AE.
    Where is the dump for P05091464AF? Have you changed the dump?
  19. The Following User Says Thank You to Rdecode For This Useful Post:
  20. #14
    Sep 2009
    1. download original vin car
    2. try code 5900 and 3095
    3. The possibility of load dump after failed attempts
  21. The Following User Says Thank You to nikz For This Useful Post:
  22. #15
    Apr 2010
    The codes are wrong for the both - radio from the label picture (P05091464AF) and "dump" radio (P05091465AE)
    He should restore original dump (P05091464AF) and code will be 9086
  23. The Following User Says Thank You to Rdecode For This Useful Post:
