Hi friends! Need your help, please!
Can?t do regen DPF with Fault P242F because fault Throttle Valve, I think...
Fault:
005445 - Throttle Valve Controller
P1545 - 002
So, I need remove Throttle and DTC!
Touareg EDC16CP34.rar
Many thanks,
Best Regards
There is swift flaps off
Pass-pm
2hard (4th February, 2017)
Yes, you?re right ICEZERO2010.But Fault Flap and MIL On car no authorize regeneration, even with VCDS force regen...
Throttle valve or flap its the same on this car, right? 3.0 V6 TDI
Ok! I messed up.
Is Intake manifold flap V157 not swirls flaps! So, the file from NIKKA not work for my problem..
Why I have to do always with VCDS? Does not regenerate normally without faults on ECU?
I try with VCDS "Particle Filter Emergency Regeneration" but always have "Regeneration Abort Recognized"
Help me Please!
kinketotua (23rd January, 2017)
Icezero - Can You explain, why DTC Off car dont do regeneration?
Pike - I removed mechanically, but the throttle have worn teeths, so....
File tva off.
