Here you have
Pass in PM
Here you have
Pass in PM
the engine does not work
Wysłane z mojego SM-G925F przy użyciu Tapatalka
I had to upload my original bin that lit now works
galleto writing 100% and error
For all kind of VAG cars with PCR 2.1 ecu you have to Unlock eep before write any modified file !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
bobolin4o (26th January, 2017)
You have to open ECU and Unlock it!
first write org back and start car after that open ecu and use unlock tool
another question or detach the plug from the EGR
You can leave egr plugged
unlocked and further 100% and error
Did you succed in puting original flash back into ECU? I think you might have a problem with your galletto tool. It might be questionable quality. If you also have kess try flashing with kess and live aside fgtech for this ecu.
but first put original back
oryginał flashing ok.write
can someone fix EEPROM to try
