Originally Posted by
predadan79
It seems to be a wiring harness problem, as we have a shortcircuit at +12V, so the diagnostic manual says to proceed at verifying for CONTINUITY AND ISOLATION AT +12V, forthe first one :
ECU, black conector A with 32 pins, pins H2 , G2, H3 with similar potetiometer pedal pins, respectively : 1, 2 and 6.
After you have to measure the resistance of potentiometer track 2 between the pins 2 and 6 = 2.857+-2.05 kohms.
for the second one :
ECU, black conector A with 32 pins, pins F3 , F2, F4 with similar potetiometer pedal pins, respectively : 4, 3 and 5.
After you have to measure the resistance of potentiometer between the pins 5 and 3 = 1.7+-0.9 kohms.
