vrobi72 (8th February, 2017)
File for you with EGR OFF and CRC FIX by genuine WINOLS
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
HELLO .. i have same problem .. z16xe p0400 , p1405 , multec 2002
ecu: HW: DEL 0115351289SW: 09353489.5
VIN nr.: w0L0TGF4825033####
SW ver.:
Spare:
Engine: Z16XE
HW Ver.:
SW upg.: DJTX
Installation:
thanks .. in advance
EDIT .. SOLVED WITH EGR REMOVER 2017.. READ & WRITE WITH GALETO 1260 , SELECT HIBRIDA 256KB . ALL OK . NO DTC..
IF U NEED , U CAN USE MY FILE ..NO PASS
hello, does it works good?
