Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
    Jun 2016
    Budapest HUNGARY
    Default Zed Bull other operations, other with programs
    Several operations have what we can not do now the programs or not quite good Solution is Now
    I'm trying to understand and I'm trying to write Small additional programs.
    The ZedBull developer is very strong protected access.
    I test WinXP and Read info; Read chip (4D) ; write 4D works.
    The PG4 combobox upload from directory system. (directory name)
  2. The Following 13 Users Say Thank You to f2f2 For This Useful Post:
    brownbajan (2nd November, 2017), doctore (3rd February, 2017), DOUGLASDL (3rd February, 2017), ecufix (2nd February, 2017), gecibogar (17th December, 2018), gepakg (5th February, 2017), joe06 (24th March, 2018), lion0304 (5th February, 2017), Lopegr (27th August, 2017), Louislesinge (8th October, 2019), pashko90 (17th May, 2018), rhj (16th February, 2017), Siham (5th February, 2017)
  3. #2
    Jun 2016
    Budapest HUNGARY
    ....Moment
  4. The Following User Says Thank You to f2f2 For This Useful Post:
    gecibogar (7th May, 2019)
  5. #3
    Jun 2016
    Budapest HUNGARY
    Add function
    PC command Zed Bull reboot. Reset,New welcome message and info display.....
    Add project system (add project to select pg4 directory )
    Program start load the last key data
    HUNtpRW[4D].Exe
  6. The Following User Says Thank You to f2f2 For This Useful Post:
  7. #4
    paganini's Avatar
    Serbia
    Can you share this program?
  8. #5
    Jun 2016
    Budapest HUNGARY
    Yes
    a bit more I'm working on it after you can try
    I tested only winXP.
    But you have Zed Bull Clone ?
  9. The Following User Says Thank You to f2f2 For This Useful Post:
  10. #6
    Jun 2009
    I have Mini Zed Bull clone but without RJ45 connecter.
    Does your programm work with my zed bull ?
  11. #7
    paganini's Avatar
    Serbia
    Yes I have Zed Bull Clone
    Quote Originally Posted by f2f2 View Post
    Yes
  12. #8
    Jun 2016
    Budapest HUNGARY
    RJ45 connecter. ..... This no problem
    right point can be incorporated within MAX232 chip 4 pieces of capacitor
    connection point 1.GND 2. +5V 3.RxD 4. RxD to Max232 and to RS232 1 RxD 2 TxD 3 GND 4 optional +12V If TPX cloner hardware tape hack.
    and connector
    build on his side
    You may be used
    JMA TPX cloner or Clone version
    Or hack2 no need max232
    Zed bull to RS232 connected GND RDX TXD logic0 0Volt Logic1 +5V
    The work TPX cloner
    2 pin build to free RS232 pin
    If necessary drawings I send pictures
    This 2 version
    1. serial comport mode -9V +9V communication
    2. direct mode without voltage driver chip
    I help you in ?
  13. The Following 2 Users Say Thank You to f2f2 For This Useful Post:
    chli1976 (5th February, 2017), gecibogar (7th May, 2019)
  14. #9
    Jun 2016
    Budapest HUNGARY
    HUNtpRW[4D].zip
    HUNtpRW[4D] exe works ZED BULL Clone
    reboot; get info;4D read;4D write
    All data save to project
    Install step
    zip file unzip to disk
    connection Zed Bull device with the USB cable
    Star EXE list all COMport and Click Start automatic search Zed Bull hardware and
    created file ZEDBULL.COMPORT
    If exist ZEDBULL.COMPORT file and hardware opened okay then no automatic comport serach panel
    Exe work Read 4D chip; ZB. display RESP data to manual mode edit program RESP textboxs
    if no exist pg4 data after TPX cloner pg4 read manula mode (COPY 4D;TPX Cloner; .....) pg4 to manual mode edit program PG4 textbox
    pg4 name edit and Click ADD TO DATABASE
    All project reload enabled okay
    In case of problems emergency exit -> Right Mouse but
    If read no correct and cycle read then click Right Mouse; next step Click Reboot; Read chip
  15. The Following 32 Users Say Thank You to f2f2 For This Useful Post:
    ancient (25th October, 2017), Bishop c4 (17th November, 2019), brend (5th December, 2017), CHIKO (13th October, 2018), chli1976 (5th February, 2017), CLK1201 (6th February, 2017), doctore (5th February, 2017), DOUGLASDL (6th February, 2017), dtii (2nd February, 2024), ecufix (9th October, 2019), fadhle (5th February, 2017), Fykus9 (31st January, 2023), gecibogar (7th May, 2019), gepakg (4th February, 2017), hbalazs (14th February, 2017), iozo (6th February, 2017), janusz21 (5th February, 2017), just4upal (6th February, 2017), kronk92 (10th February, 2017), lion0304 (5th February, 2017), Lopegr (27th August, 2017), lupu_sandu (5th February, 2017), pike (4th February, 2017), rumensivanov (5th November, 2020), SALAS (12th October, 2017), seregka (26th September, 2019), Siham (5th February, 2017), speedy100 (19th April, 2017), stivencho (22nd February, 2017), sv2hqx (4th February, 2017), tajtee (7th May, 2018), yellowstilo (5th February, 2017)
  16. #10
    Jun 2009
    Please, send pictures, Thanks
  17. #11
    Jun 2016
    Budapest HUNGARY
    The Mini Zed Bull and TPX cloner 100% works
    The TPX cloner +12V from Zed Bull (RS232)
    1. Work
    Zed Bull 3 or 4 pin connected
    2. Work
    TPX cloner optional 12V tape to RS232 and the MA3223 chip pin13 output channel (TxD)
    and pin15 input channel (Rxd )
  18. The Following 11 Users Say Thank You to f2f2 For This Useful Post:
    ancient (8th February, 2017), chli1976 (5th February, 2017), doctore (5th February, 2017), DOUGLASDL (6th February, 2017), dtip (6th February, 2017), gecibogar (17th December, 2018), just4upal (6th February, 2017), key4man (7th February, 2017), Lopegr (27th August, 2017), Louislesinge (8th October, 2019), mikajna (7th February, 2017)
  19. #12
    Jun 2016
    Budapest HUNGARY
  20. The Following 11 Users Say Thank You to f2f2 For This Useful Post:
    brend (5th December, 2017), chli1976 (6th February, 2017), doctore (5th February, 2017), dtip (6th February, 2017), gecibogar (7th May, 2019), hbalazs (14th February, 2017), just4upal (6th February, 2017), Lopegr (27th August, 2017), rhj (16th February, 2017), tajtee (7th May, 2018), yellowstilo (7th February, 2017)
  21. #13
    Aug 2015
    Zedbull cant write any TPX chip and i think it is hadware flaw....4d clone box will calculate but how do you write TPX chip with zedbull ?
  22. The Following 2 Users Say Thank You to dtip For This Useful Post:
    doctore (6th February, 2017), mikajna (6th February, 2017)
  23. #14
    Jun 2016
    Budapest HUNGARY
    So far I could not be TPX1 and 2 write.
    I write 4C and 4D to EH2 and I take expensive machines Copy TPX.
    But now I test Zed Bull direct control (PC LPT port to PCF7991AT)
    Now read TEMIC 11 12 Megamos 13 LPT port.
    If the technique so that I can expand it is a special wiring you can then write :
    TPX1 /2; TPM1-ID(TP08 clone chip) ; TP04
    Or direkt LPT port or microcontroller build to Zed Bull.
  24. The Following 6 Users Say Thank You to f2f2 For This Useful Post:
    aandroma (16th February, 2017), chli1976 (6th February, 2017), doctore (6th February, 2017), gecibogar (7th May, 2019), mikajna (7th February, 2017), tajtee (7th May, 2018)
  25. #15
    Jun 2016
    Budapest HUNGARY
    Wiring diagram for Mini Zed Bull and TPX Cloner use
    TTL assign level communication.
  26. The Following 8 Users Say Thank You to f2f2 For This Useful Post:
    chli1976 (6th February, 2017), EthicalDeviant (5th October, 2019), gecibogar (7th May, 2019), hbalazs (14th February, 2017), mikajna (9th February, 2017), rhj (16th February, 2017), tajtee (7th May, 2018), yellowstilo (7th February, 2017)
