This software work with KKL serial interface. It Is tested on my ALFA ROMEO 2.0TS motronic 1.5.5 and work fine.
you can get this for free on the yahoo group, there's support for it there as well.
Can you explain this a little clearer please......for us older folk
Will it work with a laptop and a 156 alfa 1.8Tspark??
why no use , new alfadiag in version 3.3.0.11 ?
- working also with alfa romeo 156 TS.
It use a definition to conect to the ecu.
Every diagnostic sw has, but item are in different forms inside the sw.
If u have any problem to choose them u can rename them to much easy to use.
You must choose right definition, otherway it show up errors.
Hello, this program needs to keygen ?
no, only alfadiag-loader
hi am a newbie here...i am tryin to diagnose my alfa romeo 156. which i dont know whether its a OBD1 or OBD2...but it has 16 pin holes.does it mean its a OBD2? which software do u recommend?thanx in advance
- if car is made between 1990 and to 2000 use interface VAG KKL under USB.
- software is :
- UnidiagKWP2000, have some broken DEF file , but is working, time to time
- KWP71 for ABS AirBag, excellent software, very good !!!!
- end at last alfadiag with alfadiag-loader, use only version to 3.3.0.11 ( don't use last version, 3.3.1.0 , need activation via the license manager).
where to get version to 3.3.0.11? thanks
Hello, where can i find alfadiag-loader?
i have alfa 145, i tried unidiag an it work but don't give all DTC
Thanks![]()
If you'll search you'll find it.
try here:http://www.digital-kaos.co.uk/forums...lection-65195/
