Results 1 to 13 of 13
    Jun 2016
    Default Opel Astra cluster not display km only ---- after battery drain
    Cluster not shows km and trip km. I post 95080 eprom from dash.
    ADam
    dump bad.................
  3. The Following User Says Thank You to nikz For This Useful Post:
    lexuspiotrkow (31st January, 2017)
    Jun 2016
    I saw this. example #228 to #27F. i have to second dash file and virgin than program to car or somebody know how repair this dump?
    Dec 2016
    ASTRA H not 95080
    astra h 35080 eeprom
    Jun 2016
    Astra J has 95080 and in this car as Insignia after battery drain corrupt date in cluster eprom. You have to learn
  7. The Following User Says Thank You to lexuspiotrkow For This Useful Post:
    volodin69 (3rd May, 2022)
  8. #6
    In second dash just write original chassis no and it will be fine
  9. #7
    UK East
    Quote Originally Posted by lexuspiotrkow View Post
    To be fair you didnt state whether it was a H or a J
  10. The Following User Says Thank You to plasma533 For This Useful Post:
    PierreTheron (31st January, 2017)
  11. #8
    Jun 2016
    Quote Originally Posted by plasma533 View Post
    My fault!!!
  12. #9
    Jun 2016
    I bought second used dash. KM shows only for 1 second and then -----. Problem is with immo identyfication probably on second cluster but I can't program this cluster by opcom. There is only variant programming. Maybe original tech can do this. Can you give me pin from clusters eprom? Or only from Bcu? I post ori and buy cluster dump.
  13. #10
    If you would have done what i said and changed vin number it should have been ok change vin
  14. The Following User Says Thank You to diagtech For This Useful Post:
    lexuspiotrkow (12th February, 2017)
  15. #11
    uk
    here is your file from new dash with vin number edited ...
  16. The Following User Says Thank You to raf0468 For This Useful Post:
  17. #12
    Jun 2016
    I know were is vin in file. if manualy enter vin in dump and it works what about configuration? I saw that second used buy cluster has tire pressure monitoring than original not and original cluster shows tank meter for benzin and gas injection after I put LPG buton tank meter change value but on second not working this function. In opcom menu I can't find this options to change in cluster. Maybe ori Tech.
  18. #13
    May 2022
    Hello!I would like to download it
