Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
    BestElectrical's Avatar
    San Diego, CA, USA
    Default Steering Angle Sensor internal code Toyota prius 850 degrees stuck
    Hello, could somebody clear the internal code from this steering angle sensor?
    Thank you,
    PN: 89245-74010
    Chip: 93c66
    89245-74010 steering angle sensor 850deg code 93c66b.rar
  2. The Following User Says Thank You to BestElectrical For This Useful Post:
    br.balazs (25th February, 2017)
  3. #2
    Dec 2012
    EU
    Quote Originally Posted by BestElectrical View Post
    Thank you,
    PN: 89245-74010
    Chip: 93c66
    I dont think so.some things have to be fix properly
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  4. The Following 2 Users Say Thank You to gttuning For This Useful Post:
    Abdo Abdelatif (24th May, 2018), BestElectrical (1st February, 2017)
  5. #3
    San Diego, CA, USA
    Quote Originally Posted by gttuning View Post
    Somebody took the wheel off to check the clock spring and turned the steering angle sensor more than 850 degrees so it is now stuck at 850. I have seen some people remove that code from dump and steering sensor worked after that fine. There is no problem with the sensor.
    Thank you,
    BE
  6. #4
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    You can try to remove the 4 bytes after "aa 55" in line 80
  7. The Following User Says Thank You to repairmymodule For This Useful Post:
  8. #5
    San Diego, CA, USA
    Quote Originally Posted by repairmymodule View Post
    Thanx, after writing back I scan it has a same code, and still have 850 degrees stuck.
    Any other Ideas?
    Thank you
  9. #6
    Aug 2014
    My last guess would be to also clear out the data in line A0 after the 2 bytes "aa 5a"
    Sorry I can't be more helpful,
    Good luck!
  10. The Following 2 Users Say Thank You to repairmymodule For This Useful Post:
    ahmad emamy (11th January, 2019), BestElectrical (1st February, 2017)
  11. #7
    San Diego, CA, USA
    Any other ideas?
  12. #8
    Brayn's Avatar
    Oct 2015
    Colombo
    Yes can reset and corect errors
    Sent from my F3216 using Tapatalk
  13. The Following User Says Thank You to Brayn For This Useful Post:
  14. #9
    Oct 2011
    Can you solve the problem ?
  15. #10
    San Diego, CA, USA
    Quote Originally Posted by Brayn View Post
    Please do.
    Thank you
  16. #11
    PierreTheron's Avatar
    Centurion,South Africa
    Or just use original dump and set the angle sensor closer to zero while cheking it on diagnostics
  17. The Following User Says Thank You to PierreTheron For This Useful Post:
    rtbdiagnostic (23rd August, 2019)
  18. #12
    San Diego, CA, USA
    Quote Originally Posted by PierreTheron View Post
    With original dump it is always showing 850.5 degrees. Even when it is straight at 0 degrees. Toyota sensors have a specific range, if exceeded that range the sensor writes error code inside eeprom and stops working. When the sensor is connected in the car and somebody is checking if the clockspring is good, they go over the range with a good clockspring killing the sensor.
  19. The Following User Says Thank You to BestElectrical For This Useful Post:
    PierreTheron (6th December, 2017)
  20. #13
    Aug 2014
    Is it possible that the steering angle sensor physically broke, like how a clock spring can break by over turning? I have never taken a steering angle sensor apart on a Toyota before
  21. The Following User Says Thank You to repairmymodule For This Useful Post:
    BestElectrical (3rd February, 2017)
  22. #14
    San Diego, CA, USA
    Hi, Clockspring max turn on toyota usually around 900 degrees one way.
    Steering angle sensor max turn is less than 850 degrees. that is where the problem starts.
  23. #15
    FxShaw's Avatar
    Nov 2013
    Outta This World
    I fixed some before but older ones, none with 93c66 so far.
    I don't have a clue on this one.. what year is this prius?
