jump 4 and 13 on obd port for few minutes with ignition on
If i helped you please press thanx
BestElectrical (6th February, 2017), repairmymodule (4th February, 2017)
89245-74010, 89245-74020 i can
89245-30110
wagnov15 (2nd January, 2018)
I can do toyota any steering angle inside have 93C66 and 24c02 ....😉
Sent from my F3216 using Tapatalk
solve problem already?
LEXUS GX460 89245-30110 24C02 LEXUS IS250 89245-30110 24C02 LEXUS RX350 89245-30110 24C02 LEXUS RX450 89245-30110 24C02 LEXUS RX450H 89245-30110 24C02 TOYOTA HILUX 89245-30110 24C02 TOYOTA LC PRADO 150 89245-74010 93C66 TOYOTA PRIUS 89245-74010 93C66 TOYOTA ALION 89245-74020 24C02 TOYOTA LC PRADO 89245-74020 24C02 TOYOTA MARK X 89245-74020 24C02 TOYOTA PREMIO 89245-74020 24C02 TOYOTA PRIUS 89245-74020 24C02 TOYOTA WISH 89245-74020 24C02 TOYOTA VENZA 89245-0T010 93C66
write to private who have problem
Hi SOFTDUMP!
Could U help me with prado sensor 89245-74010?
How can i set small gears?
i test clear bin but not working!
PayPal avail
Regards:
Bob
Have U any contact with softdump?
post your origianal dump and ill clear, your dumps cleared not right
swirl (8th September, 2018)
HI! Thanks!
I posted wrong file!
there is ori.
Regards:
Bob
pass in pm , if the error does not go away, do 2 sensor turns and write again , when the sensor will work connect the diagnosis and set the angle 0,
then without moving the positions of the magnets, rearrange the central gear in the position corresponding to zero then in the wheel position straight
assemble the steering.
Do not forget to put the spiral in the center position
AdrianCR (20th January, 2021), Asifmehmmod1 (25th November, 2017), devilsadvocate (14th June, 2018), generalelect1 (6th May, 2024), jattal786 (3rd March, 2018), kredka74 (25th November, 2017), MOUS734 (28th April, 2021), rtbdiagnostic (23rd August, 2019)
