Disconnect MAF, register errors, look for basic MAF value and make higher to finish emulation.
Then needed cut many related signal... or easier connect again MAF, and feel full power with ignoring MAF reads.
can you help me to convert this file to be MAP based. Engine is swapped into Audi A3 chassis ex 3.2. Big airbox with big MAF.
03G906021PB_391592_EGR_OFF.zip
Thanks in advance
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
