Thank for answer
The daily work perfectly with dpf off but coming this two dtc and I need to remove
this error is defect oxygen sensor repair it you need it this is not dpf relevant this is for engine to check the lambda
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
hi,remove DPF PRESSURE AND TEMPERATURE SENSORS DISCONNECTED.
told you the result
pass.pm
risalelettronic (6th February, 2017)
Work perfect.... thank so much
