What equipment do I need?
your tools to remove and open the ecu from car , and same mpps tool u busted the ecu , just go to "generic menu" pinout mpps to ecu with power supply and use recovery option in boot mode
and then u read this and thank the dude for his nice explenation and u should be sorted
http://www.digital-kaos.co.uk/forums...very-with-MPPS
Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
Siham (7th February, 2017), smirnoff_rules (6th February, 2017)
Arrrghhh pin out what wires do I need ?
What's best way to supply power and what is the resistor all about
the last few l have done l didnt use resistor but risk is yours , read that dpf file and power mpps with a battery or 12v adapter
http://www.digital-kaos.co.uk/forums...=1#post2888023
jakesman (6th February, 2017)
look here someone already had this problem along time ago, or do as above, same thing,
here: in black and white not my work, http://www.digital-kaos.co.uk/forums...6&d=1362572589
Thank you all for the help but I'm unsure how to pin and connect the wires up , what do I need to buy, I'm in the UK so would maplins /halfords be a good place to buy parts.
12v could i use an old PC psu
You need to buy nothing, just a few wires and you are done with your actual equipment.
Thank you , normal wires then from like audio cables and USB leads then have plenty of them.
Is the resistor essential ? Or just ground the pin to the car battery or earthing point
Is that what essentially the resistor is doing I may have a resistor in a broken multimeter somewhere which may work
search on youtube for
Emergency Ghetto Bootmode Me7 Ecu
will show you what you need to do, simple if you break it you can make it,
solder out chip 29f400bb and write org file in
I'm terrible at soldering haha
u dont need to solder just hold pin on then leg for afew seconds to put into boot
you don't have to solder anything
open the ecu plug it in the car put a wire from ground to boot pin of 29f400 . ask someone to turn on the car while you keep the ground wire on the eprom leg . now ecu is in boot mode and you can reflash with mpps boot mode option
that's all
