Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 49
Hybrid View
    Only year 2000 goes via obd and have round connector under the hood. 2001 and up you need to take out dash and do 35080.
    Jan 2017
    Only dash or LCM to?
    Gdansk Poland
    If you have new dasch and old lcm and ews then you need modify only dasch. You need open dasch and read eprom. I think pasoft 1,4 can modify vin in dach by obd but km must modify directly in chip.
    Jan 2017
    I only have Digiprog 3.
    also have a used LCM inside, because old one was broken
    Oct 2010
    Well to start off with do, dash 35080 chip, DP3 will handle that chip fine, LCM you can do using obd after
    Default BMW e46 Digiprog 3
    In this case for you is better to use x-prog. 3 in 1. Manual-pinout, km, vin.
    10min. and done.
    Wysłane z iPhone za pomocą Tapatalk
    Jan 2017
    Never heard of xprog. Send me link pls
    http://www.eldb.eu/index.php?route=p...tegory&path=35
    Jan 2017
    Cant i change vin over eeprom with Digiprog?!
    Oct 2015
    Quote Originally Posted by zix1 View Post
    Yes you can !
    If I help you don't forget thanks button
  11. The Following User Says Thank You to memet99600 For This Useful Post:
    zix1 (10th February, 2017)
  12. #11
    Jan 2017
    Im failing to find a hexa calculator where i can manually fill in the code
  13. #12
    captain crackers's Avatar
    england
    You need an ascii to hex calculator. As a clue 31 hex = 1 ascii, 32 hex = 2 ascii etc. Arthur.
  14. #13
    Jan 2017
    Yeah im failing to find one where im able manually type in the code
  15. #14
    Alawigmx's Avatar
    Aug 2016
    Sweden
    Ive only done E46's using Digimaster, just removing cluster and LCM, clearing/resetting LCM, then read/adjust mileage 35080 erase and then finally write. Works flawlessly, I mostly use Digiprog for OBD odometers in VAG cars.
  16. #15
    Jan 2017
    Quote Originally Posted by Alawigmx View Post
    Everything possible with Digiprog to. Why using an extra tool.
