The worst with option to improve after someone this. Especially if the ori of file has not.
I'm not an expert in EDC17 mods and need your opinion about this file.
We were replacing turbo hose in this Amarok today (2.0TDI 120kW).
Customer has bought this car with tuned software and wonder about tune quality (he was told 140kW).
I don't have ori.
Thanks in advance
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
without orig difficult to say, as nothing to compare
I think i have the ori i Check the file tomorrow
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Apsik (7th February, 2017)
You have SW 9746
There is SW 9747 - there should be similar but you have to convert from FRF.
VAG
Rub87 (5th December, 2018)
the tuning is ok. not to much the one and only what i do better is set the overheating not to 1 (no correction ) i would rescale the temp axis and do the value a little bit higher. you need this to control the exhaust temp
i do this so . but the most other tuner do 1
in my eyes not good
Apsik (8th February, 2017)
Thank you for your feedback.
I got your point.
VW Amarok 2.0 EDC17C54 03L906012AG_536665
Map C400A 03L906012AG_1037536665_ori.rar 13x16 16 bit
Y rpm 760-4000
X mg/hub 0-70
Please tell me - what is it?
And correct ratio (factor)?
Thank!
This tune is little weak, can extract more power from cp20 160hp, if you need stock i have ,
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
Apsik (12th February, 2017)
03L906012AG_536665
original file 2.0mb
