Results 1 to 15 of 18
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default W210 220cdi EEPROM and ecu coding problem. 0281010041, A0245452832
    Hello Mates. car W210 E220cdi had ecu:0281010041, A0245452832.
    EEPROM 95P08 damaged, new ECU bought 0281010042,
    the same HW and SW. I write EEPROM virgine dump from
    here DK, also 0281010041, A0245452832.
    I forgot reflash dump for 0281010041, so virgin
    EEPROM was from 0281010041 and flash from 0281010042.
    Coding failed, many DTC's with error and coding immpossible.
    I reflash ecu as 0281010041 and EEPROM stayed that virgine 0281010041
    not helps, still the same problems:
    P1630-064 - Drive authorisation N3/9 (CDI control unit) EEPROM
    P1617-002 - EEPROM or incorrectly coded Adaptation values of EEPROM
    P1617-016 - EEPROM or incorrectly coded EEPROM COMMUNICATION
    P1617-064 - EEPROM or incorrectly coded No harmonizing version number
    and during coding process (Coding unit adaptations --> Variant coding)
    Communication error 8.581.6067
    and during VIN coding process (Chassis number)
    Communication error 8.600.0
    So i dont understand, someone coud help me with good dumps and
    adaptation process steps good procedure?
    Many thanks,
    Winwoj
    Mar 2011
    Perhaps having different references:
    ECU: 0281010041
    There may be something to escape.
    you do inmo off new ecu, and test...
    Oct 2015
    here it is just write it your car will start
  4. The Following 9 Users Say Thank You to Tedum For This Useful Post:
    antid (10th October, 2021), autoexpertdiag (11th June, 2021), IMRAN30 (15th April, 2024), jmml (19th November, 2020), mikefrvlc (7th February, 2019), Pali33 (7th February, 2019), Walter M (10th November, 2017), WinWoj (9th February, 2017)
    WinWoj's Avatar
    Jan 2012
    ECU City
    thanks, it works. I tried this solution before, but eeprom was wrong placed (turned) that's why 'eeprom communication error' receive.
    Thanks anyway, your dump helps me understand whats problem was
    cheers!
    Oct 2015
    Quote Originally Posted by WinWoj View Post
    cheers!
    goood
  7. The Following User Says Thank You to Tedum For This Useful Post:
    mikefrvlc (25th February, 2019)
  8. #6
    Oct 2010
    EU
    Hi all,
    i have problem with coding. I can not change the coding (auto transmision). I have the same ECU like in post1 (0281010041, A0245452832, E220CDI(W210) MY2000)
    If i do new coding, it will be normal accepted, but when i look the coding again, no changes (allways i see "improper coding").
    I thing, the eeprom is corrupted.
    Can someone fix my dump? Or give me some good dump?
    many thanks in advance
  9. #7
    May 2016
    Default i have same ecu
    Quote Originally Posted by Tedum View Post
    start immo problem, if i write this dump in eeprom it start. is immo off thank's
  10. #8
    May 2016
    hello, i have same problem, julie emulator not work, please can you send me de pass for .rar archive. thank's
  11. #9
    May 2016
    thisis original dump
  12. The Following User Says Thank You to mikefrvlc For This Useful Post:
    Pali33 (26th February, 2019)
  13. #10
    Jun 2012
    Bulgaria
    I have the same problem. Can you give me the password for synced.rar. thanks
  14. #11
    alclot's Avatar
    Melee Island
    Hi mate,
    I have the same problem with one Mercedes 0 281 001 88 1 and dtc P1630. Can you help me with it please?
    thanks a lot
  15. #12
    Jun 2013
    Hi.
    Can you please give me acess for synced file?
    My S210 sometimes fails to start and i think this could solve that problem.
    Best regards
  16. #13
    Jun 2013
    Hi. Thk's for file. Can you give me password?
    If i understand this file is for 95P08 eeprom on ECU and immo is disabled, is this right?
    Best regards.
  17. #14
    Sep 2015
    GIVE ME PASSEWORD PLEASE
  18. #15
    Sep 2015
    [QUOTE=Tedum;2952475]here it is just write it your car will start[/ PASSWORD PLEASE
