Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Hybrid View
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default W210 220cdi EEPROM and ecu coding problem. 0281010041, A0245452832
    Hello Mates. car W210 E220cdi had ecu:0281010041, A0245452832.
    EEPROM 95P08 damaged, new ECU bought 0281010042,
    the same HW and SW. I write EEPROM virgine dump from
    here DK, also 0281010041, A0245452832.
    I forgot reflash dump for 0281010041, so virgin
    EEPROM was from 0281010041 and flash from 0281010042.
    Coding failed, many DTC's with error and coding immpossible.
    I reflash ecu as 0281010041 and EEPROM stayed that virgine 0281010041
    not helps, still the same problems:
    P1630-064 - Drive authorisation N3/9 (CDI control unit) EEPROM
    P1617-002 - EEPROM or incorrectly coded Adaptation values of EEPROM
    P1617-016 - EEPROM or incorrectly coded EEPROM COMMUNICATION
    P1617-064 - EEPROM or incorrectly coded No harmonizing version number
    and during coding process (Coding unit adaptations --> Variant coding)
    Communication error 8.581.6067
    and during VIN coding process (Chassis number)
    Communication error 8.600.0
    So i dont understand, someone coud help me with good dumps and
    adaptation process steps good procedure?
    Many thanks,
    Winwoj
    Mar 2011
    Perhaps having different references:
    ECU: 0281010041
    There may be something to escape.
    you do inmo off new ecu, and test...
    Oct 2015
    here it is just write it your car will start
  4. The Following 9 Users Say Thank You to Tedum For This Useful Post:
    antid (10th October, 2021), autoexpertdiag (11th June, 2021), IMRAN30 (15th April, 2024), jmml (19th November, 2020), mikefrvlc (7th February, 2019), Pali33 (7th February, 2019), Walter M (10th November, 2017), WinWoj (9th February, 2017)
    WinWoj's Avatar
    Jan 2012
    ECU City
    thanks, it works. I tried this solution before, but eeprom was wrong placed (turned) that's why 'eeprom communication error' receive.
    Thanks anyway, your dump helps me understand whats problem was
    cheers!
  6. #5
    Oct 2015
    Quote Originally Posted by WinWoj View Post
    cheers!
    goood
  7. The Following User Says Thank You to Tedum For This Useful Post:
    mikefrvlc (25th February, 2019)
  8. #6
    May 2016
    Default i have same ecu
    Quote Originally Posted by Tedum View Post
    start immo problem, if i write this dump in eeprom it start. is immo off thank's
  9. #7
    May 2016
    hello, i have same problem, julie emulator not work, please can you send me de pass for .rar archive. thank's
  10. #8
    May 2016
    thisis original dump
  11. The Following User Says Thank You to mikefrvlc For This Useful Post:
    Pali33 (26th February, 2019)
  12. #9
    Jun 2012
    Bulgaria
    I have the same problem. Can you give me the password for synced.rar. thanks
  13. #10
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi mate,
    I have the same problem with one Mercedes 0 281 001 88 1 and dtc P1630. Can you help me with it please?
    thanks a lot
  14. #11
    Jun 2013
    Hi.
    Can you please give me acess for synced file?
    My S210 sometimes fails to start and i think this could solve that problem.
    Best regards
  15. #12
    Jun 2013
    Hi. Thk's for file. Can you give me password?
    If i understand this file is for 95P08 eeprom on ECU and immo is disabled, is this right?
    Best regards.
  16. #13
    Sep 2015
    GIVE ME PASSEWORD PLEASE
  17. #14
    Sep 2015
    [QUOTE=Tedum;2952475]here it is just write it your car will start[/ PASSWORD PLEASE
  18. #15
    Sep 2023
    Default sprinter ecu
    Hi All, hi Tedum!
    Please help me. I have got a MB sprinter w903 316 cdi. The original ecu is broken. I read original 5p08 but only FF wasi in it. I bought the used ecu. I copied the flash (29f800bt) and i used the immo tools syncronize the ecu and immo box. The display does not write "start error" but the engine not running. I read the ecu: P 1617-064
    Please help me, what is wrong?
