Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    bank's Avatar
    Feb 2017
    Ukraine
    Default Opel CD70 and CID carpass
    Hi all!
    I bought VDO Siemens CD70Navi (13188477, LQ) with Siemens CID (24461297, DB). It is coded. Seller says - do not know of any code.
    OP-COM says it's paired. But it seems like DIS and EHU from different cars, because the message "Display Safe" appears after swith on.
    Using EZP2010 and clip I read dump CD70 from 24c64 and dump CID from 93c66.
    But, when I read dump from CID, every time it's different.
    Is it possible to read dump from CID without de-soldering chip?
    Is it a correct chip for reading?
    Can you help me?
    UPD. After changing type of chip to AMTEL AT93C66 8bit I think received dump is correct
    It's here, CarPass 6487?
    CID - 6847
    bank's Avatar
    Feb 2017
    Ukraine
    drahe, thnx.
    And what about CD70?
    2all: Who can help with making delivery state for these CD70 and CID dumps?
    shooting's Avatar
    WALES
    Quote Originally Posted by bank View Post
    drahe, thnx.
    Need to read Lower eeprom from CD70
    wbr
    See pic:
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  5. The Following 2 Users Say Thank You to shooting For This Useful Post:
    bank (10th February, 2017), nikz (10th February, 2017)
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by shooting View Post
    OK, I see. Got it!
    code 2608.............
    shooting's Avatar
    WALES
    OK, I see. Got it!
    Here you go, unregistered.. pair using 6847
    wbr
  9. The Following 6 Users Say Thank You to shooting For This Useful Post:
    Albert G (10th February, 2017), bank (10th February, 2017), julajus (4th March, 2021), nikz (10th February, 2017), sanixmen (10th February, 2017), TERNOCOD (10th February, 2017)
  10. #8
    bank's Avatar
    Feb 2017
    Ukraine
    wbr
    Thank you!
    I'll try and say about result
  11. #9
    bank's Avatar
    Feb 2017
    Ukraine
    CID and CD70 was paired using 6847 successfully.
    But ... after pairing EHU and DIS reboots and sound from CD and FM disappears
    Unpair doesn't help. I hear "beeps" with display safe message, but sound from CD/Radio.
    Navi works with sound.
    Any ideas how to fix?
  12. #10
    shooting's Avatar
    WALES
    Looks like your screen is in Delivery Mode, you need to use OPCOM/TECH2 to set it to paired
    wbr
    SEE:
    If you see "DISPLAY SAFE" flashing every 10 seconds, this means that the Display
    is currently in Delivery Mode, and is now ready to be programmed to the vehicle
    with a OBDII programmer.
  13. #11
    bank's Avatar
    Feb 2017
    Ukraine
    SEE:
    Yes. As I say earlier, DIS and EHU was paired successfully (without any SAFE massages). But after pairing sound from radio and CD dissapears.
    So, I unpair devices to delivery mode, after that a hear "beeps", and still no sound from FM/CD.
    But, problem with sound was solved for me by resetting EEPROM via extended SETTINGS menu (press "Main", then "Setting" for 10sec until the message "Test mode switched on", then "BC", then "Audio" some times untill come to a screen with checkboxe "Reset EEPROM")
    Thanks a lot!
  14. The Following User Says Thank You to bank For This Useful Post:
    shooting (10th February, 2017)
  15. #12
    Feb 2016
    Kosov,Prizren
    Hi i ordered a KS CID and seller said he doesnt know the code i can read the eeprom my friend has xprog and upa can anyone help me to unregister it when it arrives any day now?
  16. #13
    bank's Avatar
    Feb 2017
    Ukraine
    Post dump here and you'll receive pin
  17. #14
    Feb 2016
    Kosov,Prizren
    Will do as soon as it arrives thnx in advance
  18. #15
    Feb 2016
    Kosov,Prizren
    Hello screen arrived can anyone help me with the pinout of the CID so i can test it before i connect it to my car
