Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 38
  1. #16
    bank's Avatar
    Feb 2017
    Ukraine
    Pinout? What car you want to install CID in?
    CID doesn't need to change pins in display connector
  2. #17
    Oct 2018
    Default CID pass code
    Can i read the CID code in this image please?
    Help me please.
  3. #18
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by Pedro13746 View Post
    Help me please.
    It's difficult to read your poor images but looks Unregistered
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  4. #19
    Oct 2018
    Quote Originally Posted by shooting View Post
    wbr
    looks Unregistered? This CID have a code that i don't know
    in some foruns, GID/CID - Siemens VDO 93c66 code @ 1E5 1E7 1E4 1E8
    Can you help me with that information please?
  5. #20
    shooting's Avatar
    Feb 2010
    WALES
    ACTUALLY post your dump....
    wbr
  6. #21
    Nov 2015
    I need carpass from dump VDO CD 70 navi
  7. #22
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by jacck View Post
    Pin in your dump is 8079 but for CAR pin you need dump from Display not radio
    wbr
  8. #23
    Nov 2015
    It is display dump 93c66 readed as 8 bit
  9. #24
    Jul 2010
    Bulgaria
    also code 8079
  10. The Following 3 Users Say Thank You to bogege For This Useful Post:
    LABDANI AHMED (9th June, 2019), shooting (9th June, 2019), smoggy (9th June, 2019)
  11. #25
    shooting's Avatar
    Feb 2010
    WALES
    What is the problem you are having? Display and Radio are matched pairs and should work without programming
    wbr
  12. The Following User Says Thank You to shooting For This Useful Post:
    bogege (9th June, 2019)
  13. #26
    Nov 2015
    I need carpass. I want to programm new key to immobiliser.
    So if radio is paired with car then RADIO PIN = CARPASS?
    wbr
  14. #27
    bank's Avatar
    Feb 2017
    Ukraine
    If your car's VIN is W0L0AHM75A2103116, then pin (security code from carpass) is 8079.
    Carpass is the card with VIN, security code, engine type, radio type, key number etc
  15. #28
    Nov 2020
    Germany
    Hello Guys hope that someone is still active here.
    Is it necessary that the VIN on the eeprom of the CID and CD70 is the same?
    I bought a CD70 and read the Security code and the same with my CID and Changed the Code from the CID to the same as the CD70 but still doesnt work ...
  16. #29
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by xCInstinct View Post
    Did you replace both Display and radio, give full details
    wbr
  17. #30
    Nov 2020
    Germany
    wbr
    No the CID was installed since release (Astra H Opc 2008 and i got no Car Pass) but i bought the Car with an attachment Radio and i bought a used CD70 without a Security Code.
    So i read the eeprom from the CD70 (7609) and CID too (9807 must be the Original Code) and i wrote the eeprom form CID with the new Code from CD70 so both got the 7609 Code.
    But i didnt works ... maybe the China Clone Op Com is fault ??
    Thanks in advance
