tri and report
thanks button 4F0910402A mod.zip
tri and report
use thanks please
Thank you wery match, i have testet the File is very good.
H?. I check your tuning but don't understanding. Can I ask why you modified Lambda map to up? Lambda map should be modified down!
This mod file is very bad. Some maps are modified in wrong way, a lot of important didn't touch...
nice, this is how free tune should look like, 80% of the maps should be change stay stock, Torque raise from 200Rpm (nice) , fuel in Mscd was cahnge 80% of the table very bad consuption will be, but this is the point i stop checking,
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
Good morning friend
This is not a good tuning
Ecu powered, Dtc, Egr, Dpf, Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter, Dynotest development.
konq100 (12th February, 2017)
Then we expect a good tuning files
use thanks please
Yes i wait.
extremebike (21st February, 2017)
wait, it will come soon.
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
attached is correct file and work 100% no usual FREE FILE
kolbaska4u (7th September, 2018)
__ deleted
