Results 1 to 12 of 12
    Jun 2016
    Default Skoda Fabia 2008 year key programming problem
    Simply car but I have problem the first time with Fabia. Key lost and only one stay without transponder. So I read pin from dash 5J0 920 811B and first take id48. After login when I go to adress 21 choose how many key program, than stay: error red in this plays. So I take id48 can skoda and the same problem. When I think of the numer login ex 00333 comunication broken so my login code is correct.
    I don't know what is the problem.
    p1et's Avatar
    Oct 2013
    Try under channel 1. When I program keys for Fabia and VW Polo up tp 2008 with ad100 pro, need to choose system 1 instead of system 2 which it's actually is. Or use SBB, it works great.
  3. The Following 3 Users Say Thank You to p1et For This Useful Post:
    doctore (12th February, 2017), lexuspiotrkow (12th February, 2017), mikajna (12th February, 2017)
    Jun 2016
    ok I check sbb or t300. I usually used vcds. I choose channel 1 and 21 too but the same error on both.
    Jan 2010
    Create Dealer Key transponder. And code.
  6. #5
    Aug 2009
    Try.........
  7. The Following User Says Thank You to Brat For This Useful Post:
    lexuspiotrkow (13th February, 2017)
  8. #6
    Aug 2009
    Hampshire
    I had this before on a 08 fabia, i tried ad100 pro,avdi, sbb, etc, the only tool that worked was Supervag.
  9. #7
    yugo45's Avatar
    Apr 2010
    No need precode transponder, this is Immo 3 , only need Pin and regular ID48.
    Error in test value means no communication with ECU and Cluster, in most cases Immo off in ECU.
    Does it car start and run with not program key?
  10. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    doctore (13th February, 2017), mikajna (13th February, 2017)
  11. #8
    Oct 2015
    in all key lost situation in this car you have to wait about 35 minuts after login. use vcds and immobilizer 25 than channel 1...
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  12. The Following 3 Users Say Thank You to rokibar For This Useful Post:
    bobbik (8th January, 2019), doctore (13th February, 2017), lexuspiotrkow (13th February, 2017)
  13. #9
    Jun 2016
    Brat give me good solution and rokibar too but 6min after login works like a charm
  14. #10
    yugo45's Avatar
    Apr 2010
    I forgot to mention ,
    With all key lost those cluster have lock time 5-10 min , not 35.
    When you login , go you Measuring block 024 and you will see last field 5 or 10. after get 0 , go to adaption and you can program keys.
  15. The Following 3 Users Say Thank You to yugo45 For This Useful Post:
    bobbik (8th January, 2019), doctore (14th February, 2017), rokibar (14th February, 2017)
  16. #11
    Oct 2015
    when you wait 35 minutes key will usually be accepted on the first try. sometimes after 10 minutes you have to repeat the procedure several times. This is my experience and therefore recommend time of 35 minutes. ats all.
    best regards
  17. The Following User Says Thank You to rokibar For This Useful Post:
  18. #12
    Apr 2011
    in lebanon
    Hello.
    yes even it show you the lock time (0) some of times don't accept to continue, need to withing 35 minute is more guaranty.
  19. The Following 2 Users Say Thank You to haroutioun For This Useful Post:
