Results 1 to 8 of 8
    Member kevin33140's Avatar
    Nov 2016
    Default need power and egr off jetta edc16 03G906021AB - 394969
    Hello anyone can add me a power can with the egr off for my jetta 1.9 tdi of 2009 she made 105 cv thanks
    JETTA 1L9 TDI PD EDC16U34 105 CV 03G906021NA.rar
    mariusica_boy's Avatar
    Quote Originally Posted by kevin33140 View Post
    Your file stage1+egr_off.
    Pass PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following User Says Thank You to mariusica_boy For This Useful Post:
    kevin33140 (14th February, 2017)
    Nov 2016
    thank you a test and report
    Nov 2016
    You estimate how much power
    Approx 140HP/320nm
    Nov 2016
    Were you on for l egr?
    I look at your file and hysterisis egr are not on off.
    I want to avoid breaking anything on my engine.
    Address egr 13 ? 16 normally?
    You have to change 8 ? 16 this is normal?
    thank you
    thank you
    adress for hysterisis egr is: 1CA0C8 20x1, 1CA1BE 20x1
    it is enough for close egr
    Nov 2016
    Default egr off
    When I read in real time the egr moves so it is not off?
    How is this possible?
