Results 1 to 5 of 5
    Dec 2015
    Default Insignia 2.0CDTI DPF OFF PROBLEM
    Hi i have problem with insignia DPF off - 2.0 CDTI 130hp 2009,
    I make regeneration, restet dpf and write mod file - car work normal but after 250 km on dashbord - "check DPF" - on ecu no DTC error code
    Where is problem? I can Pay for good working solution.
    Nov 2011
    ChipLand Italy
    Opel Insigna edc17c19 DPFoff
    appreciated Reputations and Thanks
  3. The Following User Says Thank You to d3v1l For This Useful Post:
    zigi2006 (15th February, 2017)
    Junior Member yvk's Avatar
    Dec 2016
    Russia
    Quote Originally Posted by d3v1l View Post
    You edit only dtc mask. I think that it will not help.
  5. The Following User Says Thank You to yvk For This Useful Post:
  6. #4
    Nov 2011
    ChipLand Italy
    is not dtc's mask but dpf switch and all that a correct works needs I work with marelli from a long time.. it's the right work
    Dec 2012
    EU
    Zigi 4 posts from end of 2015🤔🤔
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
