Results 1 to 7 of 7
    Feb 2011
    Default Opel Astra G Z14XEP read pin with carprog
    20170217_124852.jpgHi All,
    I have problem with Opel Astra G Z14XEP read pin with carprog.
    Use carprog 4.74 opel K-line /Bosch ME 7.6.2 ECU Z14XEP
    carprog connect ECU,read,and only show ?????
    can somebody help me?
    Regards,
    dantetimoc's Avatar
    Mar 2010
    ok ???? at pin? vin data is ok????? if you will get ???? only at pin maybe the ecu is already reseted, in this case you will need only to program to new car....
    but the ecu is on a working car or????
    Autotuner- Kess 3, genuine master tools.
    pandokrator's Avatar
    Oct 2008
    Eu.Gr
    read it as CAN ecu,in the past i have same prob with clone c.p.
    also check it on bench if is in "security waiting time"
    bR
    Feb 2011
    read by immo data,read wrong pin.
    cubica1's Avatar
    Feb 2012
    Serbia
    I think CP clone can't read pin from XEP only from XE...try with abritus or fvdi.
    rgds,
    cuby
    Feb 2011
    Original CP read pin from XEP ?
    Jul 2015
    No, it can't.
