Results 1 to 15 of 25
Thread: BMW E93 CRASH
    Default BMW E93 CRASH
    HI
    PLEASE NEED TO CLEAR CRASH FOR BMW E93 CABRIOLET
    0 285 010 240
    65.77-9165624-01
    ACSM2
    I HAVE ONLY 1 FAULT : 9402 ROLLOVER-PROTECTION CONTROLLER INTERNAL FAULT
    THANK YOU
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Don't touch eeprom from airbag unit, first read eeprom from rollover and post here I will try clear it, and then clear errors in srs unit and done.
    Or try join resistors 2-3 ohm for plug with rollover and try clear errors in srs unit and report back.
    Best regards.
    Dragon
  3. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    elie (17th February, 2017), garagetech007 (2nd June, 2017)
    please can you clear roc crash
    6577 9180627-01
    eeprom 95080
    dragon100's Avatar
    Jan 2012
    Your repair file, report.
    Best regards.
    Dragon
  6. The Following 7 Users Say Thank You to dragon100 For This Useful Post:
    anonymous67 (3rd May, 2024), clauberty (25th March, 2017), elie (17th February, 2017), garagetech007 (2nd June, 2017), MeMpHiSj (29th February, 2020), pjcv (11th September, 2023), vladoford1 (4th September, 2021)
    Quote Originally Posted by dragon100 View Post
    Ok tomorrow i will test and reply
  8. #6
    Work 100% thank you
  9. #7
    Nov 2019
    Hi all.
    Can you advise how i get my dump/bin file? I have diagnostic software that I run from android device via bluetooth - its pretty comprehensive - x-diag pro 3
  10. #8
    dragon100's Avatar
    Jan 2012
    You should find ROC module, open, desolder eeprom 95080, read and upload file ...
    Best regards.
    Dragon
  11. The Following User Says Thank You to dragon100 For This Useful Post:
  12. #9
    Jun 2016
    BRISTOL-UK
    Default 95080 ROC BMW E93 CRASH
    hi mate can you clear crash in my file thanks
  13. #10
    Jun 2016
    BRISTOL-UK
    you have interl fault thanks
  14. #11
    Feb 2024
    Hi All
    Need to clear ROC from crashed BMW M3 e93
    6577 9180627-01 Helbako
    Faults: C0DF RollRate - SMR200ZPlausibility; 93FF / 9402 RollOverController Internal fault; 93D7
  15. #12
    dragon100's Avatar
    Jan 2012
    Your repaired file.
    Best regards.
    Dragon
  16. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    anonymous67 (3rd May, 2024), anonymous91 (26th February, 2024)
  17. #13
    May 2024
    Hi Team,
    I have a 2009 E93 with ROC internal fault.
    P/N 6577 9187933-01
    Are you able to please assist with clearing up this code on the module?
    Thank you very much!
  18. #14
    dragon100's Avatar
    Jan 2012
    Your fixed file ...remember about rep+thx ...
    Best regards.
    Dragon
  19. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    digi44kaos (8th May, 2024), djx92 (25th May, 2024)
  20. #15
    May 2024
    Finally fixed, thank you very much!
