Hi all,
Could you help me clear crash data in this SRS unit FORD FUSION HS7T-14B321-AE
MCU R7F701A033
Thanks for help
Hi all,
MCU R7F701A033
Thanks for help
Afreendalal (17th July, 2017)
I wish I could help you but I have not had any of these come in.
What tool did you read this with? I think ETL and CarProTool have clear files for these that they give with purchase of the activations. I was hoping they all did, but must not.
problem solved
Nice. Any chance you could elaborate a little and share with us how you solved this one?
AUTODIAGNOZA (18th February, 2017)
got exactly same car with same airbag module,any updates what tool can read this renesas mcu ?
I think so need read flash and save, then clear eeprom and write back flash and done , but maybe I wrong ?
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
no. if you need solution I will send.
CarProTool (cpt) can get clear file by cpt exe in realtime .
Just click get clear file button and add crash file , next you have clear file read for write by cpt
Regards
Abdo Abdelatif (2nd December, 2017)
Ringo24
Can you send solution for this srs ecu?
What tool You use for read/write MCU ?
Thaks a lot
B.R.
ETL from canada
Mr. jerry
buy the programmer and activation 500 us dollar???? not sure or $600
will read 2017 fusion and 2016 Honda civic
it is hardware module must solder pins on board
or cpt programmer but not sure
people they charge average $100-150 range to fix this new modules
this is my feed back
Tested solution guys.
Included both Dirty and Clean files! PM for Pass.
AUTODIAGNOZA (14th February, 2018), bermuxa77 (19th January, 2020), ChipGods (20th February, 2018), crackintosh (12th July, 2019), credoline (17th October, 2019), Dan007 (24th April, 2019), darktnt (9th January, 2020), den5 (7th November, 2019), dusiukas (29th January, 2018), FxShaw (31st January, 2018), georgije (18th November, 2019), gonzcaal (15th August, 2018), greencamp (5th January, 2018), harold1987 (13th August, 2018), hexguru (9th January, 2020), Inquizit0r (15th December, 2018), ivyura1977 (13th March, 2018), juozas10 (1st December, 2017), karzan1977 (10th April, 2019), long beach (26th March, 2018), luis12 (1st December, 2017), lwood (16th August, 2018), mcm44 (2nd December, 2017), mkopytekchi89 (3rd April, 2018), mrandrerio (10th April, 2020), natcorporation (8th May, 2018), repairmymodule (2nd December, 2017), samux (17th February, 2020), soploski (2nd May, 2020), supana (29th November, 2019), TJ007 (25th March, 2018), valdirld (1st December, 2017), websergei (30th January, 2020)
Friend wich programmer used ?, are BIN format ?.
I used CPT to download and clean the file. Both files in BIN format so you can compare them to see what lines to clear.
crackintosh (12th July, 2019), eudes (4th July, 2018)
RENESES R7F.
Dan007 (24th April, 2019), natcorporation (8th May, 2018), TJ007 (25th March, 2018), valdirld (4th December, 2017)
HI .
CAN YOU SEND ME PASSWORD PLEASE.
THANK YOU
