Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Apr 2010
    Default BMW edc17cp45 remap
    hi, exist a boot pin for this ecu in front side? i cant disassemble it, i have tire that i damage it or will broken ...
    dominik.m's Avatar
    Jun 2009
    POLAND
    It's not possible in front side.
    dominik.m's Avatar
    Jun 2009
    POLAND
    It's my solution 100% ok.
  4. The Following 7 Users Say Thank You to dominik.m For This Useful Post:
    cklair (3rd September, 2017), Gator (19th February, 2017), gelomeloman (24th September, 2019), kophiphi (1st July, 2019), paskuale (18th June, 2017), Pzolee (20th April, 2017), yeager (18th February, 2017)
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    how close is the board from the metal ?
  6. #5
    dominik.m's Avatar
    Jun 2009
    POLAND
    about 3 millimetres
  7. The Following User Says Thank You to dominik.m For This Useful Post:
    smirnoff_rules (18th February, 2017)
  8. #6
    Apr 2010
    and read write obd2 not possible? i can read flash whit gal2 in obd as bmw series 7 edc17co02/06 ... write will work too?
  9. #7
    Mar 2008
    birmingham
    people wouldnt risk cutting into case of ecu if it was
  10. #8
    Aug 2012
    this ecu is simple to open complete check youtube edc17cp45 open
    https://www.youtube.com/watch?v=mUOrKiZzIL0
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  11. The Following User Says Thank You to icezero2010 For This Useful Post:
  12. #9
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    With CNC router is better instead of flex or dremel.
    https://www.youtube.com/watch?v=11gn0N_le4E
  13. The Following User Says Thank You to konq100 For This Useful Post:
    dune85872005 (20th February, 2017)
  14. #10
    Dec 2012
    EU
    Simple until you damage one and its not that simple after.
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  15. #11
    Dec 2012
    EU
    Same like edc16c31 Mercedes.
    I open maybe 7 of them with out any issue and my own sprinter van brook.
    So i need open ecu and brick.
    From now on i cut for bdm access if i need.
  16. #12
    Mar 2008
    birmingham
    this guy should be a butcher
  17. #13
    Apr 2010
    i open it, reading now ... can someone make a goodremap, whit dpf inside?
  18. #14
    Apr 2010
    can someone make a good remap whit dpf inside?
  19. #15
    dominik.m's Avatar
    Jun 2009
    POLAND
    Today it is already for late on work. If you will want , then on Monday write.
