Results 1 to 15 of 24
    Jan 2016
    Default Fiat Stilo BSI dump
    Hi, is there any way to dump standard Fiat (Magneti Marelli) BSI via OBD socket? I don't want to buy expensive interfaces (AVDI etc...) and don't want to dissasamble whole unit to dump processor directly. I just need to read PIN code and add new key and remote.
    West Midlands, UK
    Not really. The BSI is communicated using a seed key/challenge/response so it does cost all of us good money to buy the tool that has worked out a) how to talk to the module b) to decrypt the module - It's not a simple OBD communication. I know you can do it with AVDI , but maybe the guys on here will tell you if its possible with the clone version ??
    Alternatively take the unit off and put it through Tango (I think that's about as cheap as it could be done) and it is only an eeprom from 2008.
    Good luck.
    Aug 2015
    I have old fvdi from fly and i can read stilo bcm, ducato, punto (even without pincode)....although had some problems with stilo not reading correctly once or twice...
    And @riprex pin is not enough to add key to fiats, you need bcm data to precode tranponder and only then you can add it using pin code...
    igorr's Avatar
    Aug 2010
    Quote Originally Posted by dtip View Post
    can you please explain how do you read punto bsi without pin,and how you read stilo before 2003
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Pin only you need for delphi to read by obd eprom without obd its job for 25min remove and read now you know
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  6. The Following User Says Thank You to doctore For This Useful Post:
    mikajna (18th February, 2017)
    Jan 2016
    Thank you all guys for useful replies. I know that precoded transponder is required, but that is something zed-bull should do. I need pin mainly for remote coding, because car came without one. But still... AVDI or FVDI interface is too much expensive for me to buy.
    yellowstilo's Avatar
    can you read the eeprom of the engine ecu ?
    When your Stilo is a 1.6 i can give you the pin code when you post the eeprom dump....
  9. The Following User Says Thank You to yellowstilo For This Useful Post:
    jakubg (4th January, 2020)
  10. #8
    Faraday's Avatar
    May 2012
    The dark side of the moon
    SMOK fiat body can help and is much cheaper then AVDI
    Can read:
    • Magneti Marelli NEC70F3227 +95160 (Read/Write EEprom , Read Flash , Read PIn Code)
    • Magneti Marelli NEC70F3378 +95160 (Read/Write EEprom , Read Flash , Read PIn Code)
    • Magneti Marelli MCU +95640 (Read/Write EEprom , Read Flash , Read PIn Code)
    • Magneti Marelli MC68HC912DG128 (Read/Write EEprom , Read PIn Code)
    • Magneti Marelli MC9S12DG256 (Read/Write EEprom , Read PIn Code)
    • Siemens MC9S12DB128 (Read/Write EEprom , Read/Write Flash ,Read PIn Code)
  11. #9
    Jan 2016
    Yellowstilo: Yes, I can read it, but have to disassemble ECU. I think my Galletto could read only that Motorola processor, but I could try it. Reading eeprom directly in ECU is backup plan, because I could calculate PIN for remote and disable IMMO - who would steal that shitty old Fiat?
    Faraday: It still costs more than whole Stilo
  12. #10
    Aug 2015
    Quote Originally Posted by igorr View Post
    Few weeks ago i had customer all lost keys for punto 2001 or 2002 i think, he came wihth fiat key code card and spare cuted key without tranponder. I connected fvdi and went to "read conf data" chose BCM delphi 93c66 and entered pin from his card when asked, i got reading and went to precode key, when i loaded dump i got totaly different pin so i thought i got bad reading at first, so i loaded dump to effi and again got same pin... i precoded key and learn it with pin i got from dump without problem, so i am guessing he got that pin card from other car or his bcm/ecu was changed from donor car sometimes, anyway i managed to read dump withput proper pin (false pin) i don't know if it becouse it is early punto (2001 i think) but you shoud try just entering any pin when reading that bcm.
    As for stilo there is not much to explain , just choose BCM marelli 912dg128 or BCM marelli 9s12dg256 , you have my latest reading of stilo 2003 (bad reading) here - http://www.digital-kaos.co.uk/forums...lo-bsi-marelli
  13. The Following 3 Users Say Thank You to dtip For This Useful Post:
    igorr (19th February, 2017), mikajna (18th February, 2017), Rys (23rd June, 2019)
  14. #11
    igorr's Avatar
    Aug 2010
    couple days ago I had same thing login from card and login from fvdi was diferent I was thinking that fvdi was make mistake but key learning was ok
  15. #12
    Aug 2015
    That is what i am talking to , you learned key with pin you got from dump probably? What year car was?
  16. #13
    igorr's Avatar
    Aug 2010
    Araund 2008 zastava 10 same as punto
  17. #14
    Aug 2015
    Ofc i know, i am from Serbia too ;-)
  18. #15
    Oct 2010
    Macedonia
    can someone confirm that with old fvdi 2014 (from FLY) can read FIAT BCM
