It's not possible in front side.
It's my solution 100% ok.
how close is the board from the metal ?
about 3 millimetres
smirnoff_rules (18th February, 2017)
and read write obd2 not possible? i can read flash whit gal2 in obd as bmw series 7 edc17co02/06 ... write will work too?
people wouldnt risk cutting into case of ecu if it was
this ecu is simple to open complete check youtube edc17cp45 open
https://www.youtube.com/watch?v=mUOrKiZzIL0
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
yeager (18th February, 2017)
With CNC router is better instead of flex or dremel.
https://www.youtube.com/watch?v=11gn0N_le4E
dune85872005 (20th February, 2017)
Simple until you damage one and its not that simple after.
Sent from my SM-G935F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
Same like edc16c31 Mercedes.
I open maybe 7 of them with out any issue and my own sprinter van brook.
So i need open ecu and brick.
From now on i cut for bdm access if i need.
this guy should be a butcher
i open it, reading now ... can someone make a goodremap, whit dpf inside?
can someone make a good remap whit dpf inside?
Today it is already for late on work. If you will want , then on Monday write.
