Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 122
  1. #61
    Aug 2016
    Hungary
    Great small program!
    Works for me on Win7 32bit with real serial port. 1T0 035 680C HW04 decoded smoothly...
  2. #62
    Feb 2016
    Romania/ Timisoara
    RNS510 code finder v2.1: https://gofile.io/?c=0LjkEJ
  3. The Following 20 Users Say Thank You to cla For This Useful Post:
    BIADI (12th April, 2020), daniel53 (1st April, 2021), florin_leo (2nd June, 2020), gafari (20th April, 2020), Golfwagen (1st April, 2020), golo (1st April, 2020), ilkovelichkov (21st April, 2020), kaziukas1958 (3rd July, 2020), kuzmichh (2nd April, 2020), lwd11 (1st April, 2020), mbi (1st April, 2020), murat332 (1st April, 2020), nelutzul40 (1st April, 2020), nigrou (1st April, 2020), paradajz (1st April, 2020), Raimax (1st April, 2020), razvanrms (1st April, 2020), sonices (1st April, 2020), svetlim (15th June, 2020), won (6th August, 2020)
  4. #63
    Nov 2013
    Macedonia
    Quote Originally Posted by cla View Post
    Not working on XP
  5. The Following 3 Users Say Thank You to Zann For This Useful Post:
    ilkovelichkov (21st April, 2020), kaziukas1958 (3rd July, 2020), shooting (1st April, 2020)
  6. #64
    nelutzul40's Avatar
    Dec 2011
    Ialomita- RO-
    Win7 and more....
  7. #65
    razvanrms's Avatar
    Sep 2015
    romania
    it works perfectly. tested on win 10 , thanks
  8. #66
    Aug 2015
    Hi, hope that someone can share comport settings and terminal configuration. I only get unreadable characters (and thus the program doesn't work). Tried both direct connection to serial port and through USB adapter. I use the same hardware to connect to Audi MMI systems without any problem. Any idea?
  9. #67
    Feb 2016
    Romania/ Timisoara
    I suppose that Audi MMI use an adapter with TLL levels. For RNS510 you need a direct RS232 connection.
    What kind of the adapter you try to use?
  10. The Following User Says Thank You to cla For This Useful Post:
    sonices (10th April, 2020)
  11. #68
    Aug 2015
    Hi, Thanks for your response. I've tried a direct RS232 to my serial and I still see garbage in my Teraterm / Putty. This is supposed to be a straight forward thing but it took me almost a day with no result
  12. #69
    May 2019
    Great!Works on win7,xp doesnt.Excellent
  13. #70
    Nov 2015
    Thank you Claudiu for a great job !!
  14. #71
    Aug 2018
    UK
    Hi Claudiu,
    Hope I can disturb you with a strange issue that I have... I think the cable works fine cause Putty is working as well (I've attached some photos), the driver seems to be installed properly, I just don't understand what I did wrong? It doesen't seem to READ Kernel and Made on.!! Can you help me please? Thank you
  15. #72
    Nov 2013
    Macedonia
    Quote Originally Posted by alexanderpuma90 View Post
    Try older version of this app.
  16. The Following 4 Users Say Thank You to Zann For This Useful Post:
    chat13 (9th March, 2023), irfa (2nd June, 2020), Papiti56 (14th December, 2021), RadioChiP (3rd January, 2024)
  17. #73
    Feb 2016
    Romania/ Timisoara
    Putty terminal shows garbage so the program isn't involved. If the interface is connected properly and the baud rate is set 115200, all the messages from Putty terminal should be readable.
    -replace the interface.
    Claudiu
  18. The Following 4 Users Say Thank You to cla For This Useful Post:
    ADEL.KSHLAF (27th September, 2023), asliyucegsm (15th June, 2020), nelutzul40 (3rd June, 2020), sonices (3rd June, 2020)
  19. #74
    Jun 2018
    United Kingdom
    Works for me.. Win 10
  20. #75
    Jun 2020
    I could not make it to work under Win XP. .Net 4.0 is the last version officially supported by MS in Win XP. But it worked perfectly fine under Win 7. US version of Touareg RNS-510: 7L6 035 684 C. Thank you.
    I also have a 7L6 035 684 B I would like to test but it shuts down during boot and I would love to diagnose it via debug console.
