Results 16 to 30 of 37
  1. #16
    Dec 2018
    pin megane 2
  2. #17
    Jan 2019
    Thank you Catalizator.
    I was still not successfull :/
    The FVDI software is not running with Renault. It crashes when loading
    What is another good solution?
    I tried so many times.
    I would also go and find another locksmith in Berlin who can help.
    Suggestions very welcome!!!
  3. #18
    Dec 2018
    hi.renault ecu tool, renolink, x100....
    and many instruments write keys. depends on the price that suits you
  4. #19
    Jul 2020
    hy guys and sorry to dig this thread up,
    I've bought the FNR to code keycards to Renaults until 2008 but is going to take a while to arrive so I also have a copy of DDT4ALL / DDT2000 around here and the proper cable to work with it, but i dont use it for a long time.
    Is it possible to programm keycards using the DDT4ALL or/ DDT2000? I saw around here some threads that it can be done but the procedure is not very clear.
    Does any one have experience with this particular procedure?
    Ive found this procedure so far:
    1.first you make read UCH
    2.ignition switch off
    3.enter APV code
    4.press buton start APV
    5.insert new key and turn ignition on
    6.after led immo off wait 5s. and turn ignition off
    7.insert next key and turn ignition on
    8.after led immo off wait 5s. and turn ignition off
    9. press Valider button and afterwards Abandon Mode APV
    10. now test new key and remote.
    I have doubts about this since there is no ignition off or on procedure if the card isnt recognized in megane 2, the ignition will only go ON if the card is already coded to the car. Can anyone confirm or correct this procedure?
  5. #20
    Jul 2020
    Hello again,
    I've been testing and found that I can't read properly the ISK for an Megane 2 PH I (its a 2004 car, im sure its Phase I) ..strange...Am I doing something wrong?
    Please check the printscreen and post your comments pls, i would appreciate some help. thank you!
  6. #21
    Jul 2020
    Here i send the response to the request on address 21AB from the UCH:
    The supposed ISK is being read correctly so i'm really in the dark here
  7. #22
    Sep 2020
    Le havre
    Hello, if you go to this table, you can normally assign the cards after retrieving the PIN code
    I made a translation of the procedure for assigning badges.procedure carte ddt4all.JPG
    read the PIN code without putting the badge in the reader.
  8. #23
    Jul 2020
    Hy Chris,
    yes, you're right but this time, i don't know why I can't get a proper PIN code from the ISK that ?m reading, I'm very confused...
    BR
  9. #24
    Sep 2020
    Le havre
    Test with Renolink 1.49 if you have an original OBDlink SX probe which you can have here:
    https://mega.nz/file/1gQlhaJb#T_CkV4...L1kiyHYyxohQbw
  10. #25
    Sep 2020
    Le havre
    Do you have this function on your DDT4ALL?
    If you don't have this extension, here is a link and you install the ddtplugins file in: C:\Python27\Scripts\ddt4all-master
    https://mega.nz/folder/0wAxgaYY#Yhrbcf3_b24O86x4MT2E0Q
  11. #26
    Jul 2020
    Quote Originally Posted by Christiano76 View Post
    I think i do, check my post #20. The window that should show is that one, right? Your DDT is in French, right?
    BR
  12. #27
    Jul 2020
    I don't have that cable and for this particular case this should be all very straight forward and so far it's not...
  13. #28
    Sep 2020
    Le havre
    yes, it's this window and my ddt4all is in French
  14. #29
    Jul 2020
    Hy Chris
    I thought so, and thank you for your inputs on this. So since I'm using every right tools and plugins i don't understand why is this happening. Someone else could give some hints pls?
  15. #30
    Sep 2020
    Le havre
    look at post #22
