Results 1 to 2 of 2
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default Star Diagnosis C4 cables - coding resistors...
    Hello Mates.
    I lost three cables from my SD C4. Have only one, for heavy duty, 14-pin cable.
    I had to connect one car, so I borrow 16-pin and 38-pin and measured
    "SD-side 38-pin A-t" to MB 38-pin and to OBD 16-pin crossing. I made it.
    I use 14-pin heavy duty 14-pin for obd 16-pin conector wiring, but DAS software
    can't connect to car...
    I measured once again my 14-pin cable, and discover 3,3kOhm between "T" and "U"
    holes... It could mean that all SD cables are coded. Maybe someone could help me
    and measure resistance between that pins in the rest of cables
    (38-, 16- and bananas-)
    in "SD-side 38-pin A-t"
    This will help you
    Cable ID 8000 8001 8002 8003 8016
    38pin OBD 14pin 4pin OBD_DoIP
    18 (U) GND GND GND GND GND
    19 (V) R0 0 1200 3300 7500 3300
    20 (W) R1 - - - - 3300
  3. The Following 2 Users Say Thank You to Room For This Useful Post:
    crackintosh (21st February, 2020), WinWoj (22nd February, 2017)
