Results 1 to 4 of 4
Hybrid View
    Jan 2010
    Default Siemens MS42 Boot pin location
    Hello to all
    I purchased a spare Siemens MS42 and comparing the board to some of the pictures posted around that show the boot pin, the board of the ecu i purchased is slightly different
    Can anyone shed some light on this?
    dominik.m's Avatar
    Jun 2009
    POLAND
    This pictures will help You. Tested.
  3. The Following User Says Thank You to dominik.m For This Useful Post:
    se93 (22nd February, 2017)
    Jan 2010
    Quote Originally Posted by dominik.m View Post
    Thank you!!!!!
    Jan 2010
    Managed to get boot mode working and was able to write the virginized file onto the MS42. Did the EWS sync and vehicle started up. With this file, i have the "Engine service light" on. What configuration function needs to be edited so it will go off as it should?
    I thought that once this flashing is done, the DME would recognize the cars VIN #? In INPA the VIN shown is not from my car but from the original car this ecu was programmed for. Are there additional steps needed to match the VIN of my car on the DME?
    Starting to work with tunerpro software and have a question
    When i load the XDF and open my 32KB read, most of the values of the maps are 0. I clicked on the softwareversion tab and there is no data and the boxes are red. What am i missing and not doing to view the data of the partial read of the virginized map?
    Sent from my iPhone using E46Fanatics
