Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Fec001's Avatar
    in this case we have one fully working original key, remote works too.
  2. #17
    Fec001's Avatar
    Can someone give me SK High and SK Low for keys number 3 and 4 please?
  3. #18
    dijo's Avatar
    Here we go...
    key3=
    sk HI= 25AD
    sk LO= 49DD3380
    config= C858C2A7
    Sync = 254CCA6A
    key4:
    sk HI=4F49
    sk Lo=E59E77A6
    config= C8AE4ECF
    Sync = CA196518
    take attention to transponder only PCF 7943PCF 7944PCF 7945PCF 7952 wil be compatible with remote function...
    if your Hitag detect 7942-45 then there is something wrong...
  4. The Following User Says Thank You to dijo For This Useful Post:
    Fec001 (14th September, 2017)
  5. #19
    drugowaz's Avatar
    Mar 2015
    Lithuania
    all china keys ive met it pcf7945 and remote works.
    interesting on pcf chip is writter 7941 . but progger scans as pcf7945
  6. #20
    Fec001's Avatar
    I still can't read the programmed key. SK high and low is given.....
    Unprogrammed key is read w/o problem, detect as PCF7945. Both key is the same type...
  7. #21
    dijo's Avatar
    M8, I dont use abrites for Hitag but you have use the wrong section...
    this section is to unlock your transponder data, there for you get error about transponder...
    you need to write your remote data on the proper area = "Remote Control Memory"
    and take care of your key!
    Key3= ID =D86A4E97
    Key4= ID =8A44FA41
    dont mix this ket ID...!
  8. The Following 2 Users Say Thank You to dijo For This Useful Post:
    doctore (14th September, 2017), Fec001 (14th September, 2017)
  9. #22
    Fec001's Avatar
    So just write data you gave me, into the "remote control memory" section?
  10. #23
    dijo's Avatar
    1 step= read your key with Hitag
    2 step= look at Identifier number (this must match to data of Key 3/4) attention here! dont mix it!
    3 step= write data to proper location in "remote control section"
    if your remote still fail to work...
    try with programming...
    switch ignition on with the key and wait 15 seconds thenturn ignition off and take key off.
    Repeat this process one time more.
    Take the key out from the ignition lock, close all doors and pushthe “Cose” button 2x times.
  11. The Following User Says Thank You to dijo For This Useful Post:
    Fec001 (15th September, 2017)
  12. #24
    Fec001's Avatar
    Thanks!! But unfortunatelly program doesn't allow to change/write remote control memory data
  13. #25
    Oct 2015
    Quote Originally Posted by Fec001 View Post
    You set in programmer correct password (isk lo&hi)?
  14. #26
    Fec001's Avatar
    So finally, remote works. Customer bring another key with good frequency(868) write with tag key tool and works ok. The first remote was 315Mhz
  15. #27
    Jun 2009
    Porto
    Took pictures of the differences in PCB? i have the same useless keys... Abrites says unrecognizable during the normal OBD/hitag procedure
  16. #28
    Jun 2009
    Porto
    Strangely, both keys i have got 13.568Mhz Oscillator, with C9 and C10 populated.
    BUT L2 received a 0 ohm resistor instead of a coil (L1 has a coil as expected)...
  17. #29
    eprst's Avatar
    Jul 2011
    Russia
    Quote Originally Posted by xaimitu View Post
    Please pictures pcb key
    THANKS + REP if I help you
