Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    Fec001's Avatar
    Apr 2010
    Default E60 CAS2 key compatible
    Hi!
    I have a customer who bought this china key. As I'm not key expert, read it with TAG key tool and make photo about ID. I want to know if I can adapt it to CAS2 system.
    numbers on key chip:
    NXP
    26A0700
    MM40403
    TX6441
    Thanks!
    Fec001's Avatar
    Apr 2010
    Any Hitag expert?
    Jun 2010
    In a van down by the river
    I really don't think it's possible. Perhaps the transponder can start car but remote definitely will not work.
  4. The Following User Says Thank You to indienick For This Useful Post:
    Fec001 (7th March, 2017)
    Nov 2015
    I've done one before...it's work but the response of the remote just not as good as the original.
  6. The Following User Says Thank You to hkcarkey For This Useful Post:
    Fec001 (24th February, 2017)
  7. #5
    Fec001's Avatar
    Apr 2010
    Adapt the key with tagkey tool by CAS2 dump. Key starts the car but remote doesn't work .
    probably because of pcf 7945.
  8. #6
    Fec001's Avatar
    Apr 2010
    Changed to PCF7944. Car starts but remote still doesn't work. Any idea?
  9. #7
    Fec001's Avatar
    Apr 2010
    Remote even can't make any radio signal. Could this be because of bad programming?
  10. #8
    bearheroes's Avatar
    Dec 2011
    How did you do that? Pcf 7944 and 7945 have different footprint...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  11. #9
    Fec001's Avatar
    Apr 2010
    Interesting, just changed it on pcb, first checked if tag key tool can recognize and adapt by cas2 dump
  12. #10
    bearheroes's Avatar
    Dec 2011
    I ask you again...how did you do that? Pcf7945 has 28 legs...pcf7944 16...
  13. The Following 4 Users Say Thank You to bearheroes For This Useful Post:
    doctore (5th May, 2017), Gavra (7th May, 2017), lush29 (14th September, 2017), musti418 (30th May, 2020)
  14. #11
    Fec001's Avatar
    Apr 2010
    That is marked as PCF7941 but tag key tool recognize as PCF7942-44
  15. #12
    bearheroes's Avatar
    Dec 2011
    Transponder's ID indicates the type...so probably both are the same...but different id...chinese games...
    Solder back ori transponder and find someone with tmpro and bmw cas function, renew it and write it again with tmpro...because only with tmpro remote will work again...
  16. The Following User Says Thank You to bearheroes For This Useful Post:
    Fec001 (6th May, 2017)
  17. #13
    HeXeN's Avatar
    Mar 2015
    where did he buy it?
  18. #14
    Fec001's Avatar
    Apr 2010
    Don'T know, customer bring it. Anyone can tell me how can I read transponder again after programming locked it? As I know I must give correct SK low and high in order read user pages. I think problem is that in user page0 the second digit is not 4 what indicates it is BMW remote.
    Can be SK low and SK high get from CAS2 dump?
  19. #15
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Did this few days ago. car starts ,but no remote s i couldt check as original owner key didnt worked to even with good frequency signal of original remote. problem in car 99% antena etc
